First time builder. Started for the first time and AIO and three case fans not spinning.
Solved by GSTARR,
Double check the power connectors (SATA for the included controller) are securely plugged in. Might as well pull them out and reconnect them to be sure.
Also try disconnecting them from the controller, and connecting them straight to the mother board to see if they spin up.
When you plug in your PSU, it should be in the off position, right by where the cable plugs in (The wall outlet cable). But, capacitors still retain some current even after you turn it off so rgb turning on when you plug it in wouldn't terribly surprise me
