S70 blade
46 minutes ago, Shailesh Vats said:btw i wanted to know more about ssds especially like dram, speed ,tbw
DRAM is kinda like a roadmap for where files are located on the drive. If you're doing a ton of very small file transfers, it will improve speed quite a bit, but the non-DRAM SSDs have gotten good enough that it's no longer really considered a necessity (personally my main system is running DRAM-less SSDs for games with no real downside). Speeds are weird, since there's the max possible throughput in ideal conditions, random performance, and other stuff in between. Most of the time the only time you'll see max throughput is if you're copying large files (I.E. movies), so not really that relevant, and in more standard conditions you want to look more at random performance, though even then there's a point of diminishing returns for most people. TBW is how long the drive will last, though do consider that unless you're constantly rewriting the entire drive that's not likely to matter all that much. For reference, my main boot drive (MSI M470 1TB) I've had running for almost 2 years, and the usage is currently sitting at 5 TBW, out of a listed endurance of 1600 TBW, so at this current rate the drive will last 640 years.
That drive is very good if it's less than an SN770, though I'd probably look at some lower end options to see if you can save a bit of money.
