I'm currently running Window's 8.1 and loaded up DII for nostalgia's sake.
The installation seemed to work normally, but when I tried to open it up for the first time I got an error. Did some searching and apparently I just had to switch the compatibility it ran under and force it into windowed mode, which is all fine and it works.
The problem is, and the solution I read about doesn't work, I'm stuck playing on a small window. I can't re-size or maximize the window at all and it makes the game awkward to play.
Any ideas?
https://linustechtips.com/topic/153839-diablo-ii-issue/
Any ideas?
If you didn't already add D2 to your battle.net account and download it from blizzard rather then using the cds, it's been updated to function better.
Case - NZXT H6 Flow : Mobo - ASRock X670E PG Lightning : PSU - Deepcool PX1000G : CPU - AMD Ryzen 9 7900X3D w/Arctic Freezer III 360  : Memory - G.Skill Ripjaws S5 32gb 6000mhz CL30 : GPU - MSI Expert 4080 Super : Storage - Verbatim Vi7000G 4tb NVME SSD  : Displays - Gigabyte 32" M32QC Curved 165hz & 27" M27Q Pro 165hz 1440p
https://linustechtips.com/topic/153839-diablo-ii-issue/#findComment-2058266
