Hey, anyone know what PSU will be able to power the Maximus VI extreme board?? (as it has a 8+4pin and then another 6pin for the pcie lanes)
<p>Mobo - Asus P9X79 LE ----------- CPU - I7 4930K @ 4.4GHz ------ COOLER - Custom Loop ---------- GPU - R9 290X Crossfire ---------- Ram - 8GB Corsair Vengence Pro @ 1866 --- SSD - Samsung 840 Pro 128GB ------ PSU - Corsair AX 860i ----- Case - Corsair 900D
https://linustechtips.com/topic/15383-z87-psu-help/
or is that 6pin a PCIE plug?
https://linustechtips.com/topic/15383-z87-psu-help/#findComment-172174
Most higher end gold/platinum PSUs 650W and above will have dual CPU power connectors.  You can ignore the 6-pin supplemental unless you are planning on 4 graphics cards.  In that case the AX1200i might be for you... or even dual 750W with a 900D or something...
Anyway, if you're planning on something like 2 GPUs, the SeaSonic X750 will be fine, it has dual CPU power and 4x PCIe connectors, so enough for two 8+8 or below GPUs.  And with two cards you won't need to worry about the 6-pin supplemental on the board, it's in a really awkward spot anyway.
https://linustechtips.com/topic/15383-z87-psu-help/#findComment-173019
check this article out, corsair has addressed this subject :).
oh damn thats a nice looking mobo!!!
Haswell compatibility with Corsair power supplies
My build for this summer, EVGA X79 Dark, 16 gigs Corsair Platinum 1866mhz, EVGA SC TITAN,  2 Samsung 840 Pro raid 0, western digital 1tbhdd velociraptor, 1200 wt psu to be continued :)
https://linustechtips.com/topic/15383-z87-psu-help/#findComment-184519
