power supply recommendation please
Go to solution Solved by jaslion,
41 minutes ago, dreamcast4599 said:
Any 400w+ a or b tier is gonna be more than fine
currently have an i7 3770 non k a 1050ti 2 2TB desktop platter hard drives and 2 8gig sticks of ddr3 ram how many eatts do i need for a psu for this system for some gaming and google chrome web browsing? if it matters cpu will be left at stock speeds no overclocking im thinking 400 watts?
https://linustechtips.com/topic/1538048-power-supply-recommendation-please/
27 minutes ago, dreamcast4599 said:
@jaslion how many amps do i need on the 12 volt rail for my 1050ti
Not much really depending on the version. Is it one with a pcie cable input or not?
Basically any good 400w+ unit will more than do. Overspeccing is fine too doesn't draw more power just gives you a broader range.
2 hours ago, dreamcast4599 said:
how do you know its an n1 unit the box doesnt list what kind it is?
'100-N1'
try this one (new)
Apevia Prestige 600 W 80+ Gold Certified ATX Power Supply (ATX-RP600W) - PCPartPicker
You can't really get a good psu under 40 bucks unless it's used (which I wouldn't go for)
if you wanna take a gamble - Thermaltake Smart 600 W 80+ Certified ATX Power Supply (PS-SPD-0600NPCWUS-W) - PCPartPicker
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
Total: £1040.95
Total: £1040.95
well @filpo i cant really afford more than 50 and thats stretching it i mean most of the parts that i have for my friends build were either parts i had lying around the house or parts people donated to help my less fortunate friend have a decent pc since he cant afford one
Then the best thing you can go for is an apevia prestige Apevia Prestige 600 W 80+ Gold Certified ATX Power Supply (ATX-RP600W) - PCPartPicker
Which is not a horrible psu by any means, it's better than the thermaltake smart
If you really want to go used
Corsair CX650M 650W 80+ Bronze Power Supply RPS0029 CP-9020103 75-011267 | PS855 | eBay
Total: £1040.95
23 minutes ago, dreamcast4599 said:
Just as bad as the n1 the suggestions people made above are about as good as it gets for the small budget
This and the n1 are basically one power outage away from a broken pc
1 hour ago, filpo said:
Produced in 2016, week 33. Already over 7 years old. And I don't see any modular cable on the pictures. Not a good purchase for $45.
