Which SATA cable first?
Go to solution Solved by Askew,
Cables or ports? Those boards only have intel SATA ports so any of them will provide the same performance.
^This, with some previous chipsets there were third party SATA controllers for some of the SATA ports, but with Z87 I think all yours are native.
Use any of them, you can configure what is read first in the BIOS settings
Andres "Bluejay" Alejandro Montefusco - The Forums Favorite Bird!!!
Top Clock: 7.889 Ghz Cooled by: Liquid Helium
#ChocolateRAM #OatmealFans #ScratchItHarder #WorstcardBestoverclocker #CrazySexStories #SchnitzelQuest TS3 SERVER
https://linustechtips.com/topic/153777-which-sata-cable-first/#findComment-2051539
I have an ASUS Z87-A, and it has 7 SATA 3 cables, and I'm going to use two of them, but does it matter which one I connect to?
i'm a potato
https://linustechtips.com/topic/153777-which-sata-cable-first/#findComment-2051544
https://linustechtips.com/topic/153777-which-sata-cable-first/#findComment-2051551
