Right, so this is sorta a part 2 of my first thread stating the temps I was getting with Gtx660 during games, underload, etc, after sending out for an RMA which the card shall be picked up monday now, I decided to hop on Tomb Raider and do the bench, turning Vsync off completely, settings at a mix of high and ultra, some settings on low, @ 1280 x 1024, Monitoring with Evga Precision X the card rocketed to 100 degrees CELCIUS. I thought this was rather alarming and I decided to download / install Furmark and burn the Gtx660 with it to test the temps when under the bench with AA on at 2x MSAA. Roughly 20 - 30 seconds passed and the card hit 100'c, card freaked out, lowered the clocks past 500 and just generally spazzed out, weird thing is, is that Furmark was displaying a different, much lower temp @ 40'c. Would attach a Screenshot of TR during Max temp but It's late. Furmark added below. EDIT: ADDED TR SCREENSHOT AFTER SETTING FAN PROFILE OF FULL FAN SPEED AT 70'C+
FurMark_2013_05_12_00_28_39_010_zpsad49c
FurMark_2013_05_12_00_28_30_693_zps6c0f2
TombRaider_2013_05_12_02_16_11_398_zps3f
Cpu: i5-2500k @4.8Ghz, MB: Asus Maximus V Formula, CPU cooler: Be quiet! Dark rock pro 2, GPU: Evga Gtx660 FTW@1.24ghz. Ram: Corsair Vengeance 8GB 1866Mhz, PSU: Be quiet! 730w Semi modular, SSD: Corsair force 3 240Gb, HDD: WD Green 1TB, Case: Nzxt H2 with 4 Corsair SP120's, Win7
https://linustechtips.com/topic/15375-gtx660-temps-once-again/
Maybe Furmark just isn't reading the info from the card properly? I don't see any other reason for the discrepancy.
- Silverstone TJ08B-E - Gigabyte Z87M-D3H - i7 4770k @ 4.0GHZ 1.2v - 16gb Kingston HyperX Black 1600 - Gigabyte GTX 770 OC 4GB -
- Silverstone Fortress FT02 - MSI Z77 Mpower - i5 3570k @ 4.0GHZ 1.09v - 8gb Mushkin Blackline 1600 - MSI GTX 670 PE -
- Lenovo T430 (1600x900) - i5 3210m - 8GB DDR3 1333 - nVidia NVS5400M - 256GB mSATA OS - 320GB HDD-
https://linustechtips.com/topic/15375-gtx660-temps-once-again/#findComment-172070
Not quite sure, but do you think RMA'ing the card will be worth it though?
https://linustechtips.com/topic/15375-gtx660-temps-once-again/#findComment-172078
Probably not a GPU problem, Furmark is just getting the wrong temperature. Happens with my card too(not always).
But with those temps there is definitely something wrong. What exact model GPU are you using? How is the airflow in your case. Is the GPU heatsink securely attached to the GPU?
At 100C it is possible to permanently damage the GPU.
If you can figure out the high temperature problem, I would just RMA it.
CPU: AMD 3950x Mobo: MSI B550 RAM: 32GB DDR4 GPU: Asus 3080 Strix PSU: Superflower Leadex 3 720w Case: BeQuiet 500DX
Storage: 2TB SSD + 4TB HDD Audio: SMSL 793ii -> HiFiman HE-400 + Mission MS-50 Speakers
https://linustechtips.com/topic/15375-gtx660-temps-once-again/#findComment-172114
Here I shall answer, Gtx660 Evga FTW edition, clocked at 1072Mhz, clocks up to 1172Mhz (Rarely), Card is currently 3 months old, no problems up until around 2 weeks ago, used to hit a max temp on SC2 of around 72'c, perfect temp, never touched the internal parts of the Card, i.e the cooler as I've seen no need. So yea.., forgot to add this, the airflow in the case seems fine, I've got 2 intakes on my NZXT H2 with my large be quiet! Dark rock pro 2 CPU cooler above the 660, With the exhaust on the back.
https://linustechtips.com/topic/15375-gtx660-temps-once-again/#findComment-172171
Are the GPU fans spinning freely? Maybe the fan is broken?
Have you set up a custom fan profile in EVGA precision? Maybe try turning up the fans to see if the temperature drops.
Also check the 4 screws holding on the heatsink to the card, they could have come loose.
If you feel uncomfortable doing this, I would just RMA the card.
I have RMA'd an EVGA card before and I had a new GPU back in my hand in less than two weeks, awesome customer service.
https://linustechtips.com/topic/15375-gtx660-temps-once-again/#findComment-172207
Cards like a bloody jet engine at the max 74% Fan speed indicated by the Screenshot, it's defo pushing air when I put my hand close to the exhaust of the card.
https://linustechtips.com/topic/15375-gtx660-temps-once-again/#findComment-172212
WOW thats insane.. check the case condition.. space.. and all fans included in the case.. also check room temps, is it new? when did you exact the problem?
i5 3570K @3,5GHz || Asus P8-Z77 V-LX || 8GB Corsair Vengeance DDR3 RAM || nVidia GTX 480 1,5GB || Corsair CX600M PSU || 120GB OCZ Vertex 3 SSD || 500GB WD Storage drive || Cooler Master K350 Case || Razer DeathAdder || Razer Black Widow 2012 Ultimate Edition
https://linustechtips.com/topic/15375-gtx660-temps-once-again/#findComment-172216
I would just RMA it, unless you want to disassemble the card and replace the thermal paste(which might void your warranty). Temps that high are very bad for the GPU, if it was at 100C for more than 30 seconds I wouldn't be surprised if it already had some damage.
https://linustechtips.com/topic/15375-gtx660-temps-once-again/#findComment-172220
I ran the card at 100'c for around 20 seconds or so Max, I really didn't want to fry it. I currently do not possess Thermal paste at the moment so even if I wanted to, I can't.
https://linustechtips.com/topic/15375-gtx660-temps-once-again/#findComment-172230
Read the quotes and/or responses, you'll get a general jist of the current situation with the card.
https://linustechtips.com/topic/15375-gtx660-temps-once-again/#findComment-172232
sounds odd, are you using beta drivers by any chance?
Sorry for not seeing this, and no, I'm using 314 Drivers?
https://linustechtips.com/topic/15375-gtx660-temps-once-again/#findComment-172412
my friend had around the same problem but he was using beta drivers the 320 i think they are.. anyway even after going back he is still getting weird errors. sorry im not being much help hope someone here can figure out whats wrong. ill do a bit of research on it on the mid time.
https://linustechtips.com/topic/15375-gtx660-temps-once-again/#findComment-172494
It's fine mate, just looks like the cooler isn't seated properly or the chip is screwed.
https://linustechtips.com/topic/15375-gtx660-temps-once-again/#findComment-172521
Check with MSI after burner for temps.
Specs: Core I7-2600K @ 4.5GHz @ 1.35V, 4x4GB Corsair Vengeance Black 1600MHz CL9, Cooler Master Evo 212, MSI Z77 Mpower Motherboard, Sapphire Radeon HD 7950 Vapor-X @ 1000/1400, Cooler Master HAF 932 Blue Edition w/ 3 Cougar Hydraulic Bearing 120MM fans (2 up top 1 in the bottom) replaced side panel with a window, and rear fan with a Cougar Hydraulic Bearing 140MM, Cooler Master GX 650 80+ Bronze PSU, Samsung DVD-RW, Samsung 840 Pro 128GB SSD, Seagate 750GB SATA III 7200RPM
https://linustechtips.com/topic/15375-gtx660-temps-once-again/#findComment-172646
