cobblemon forge
Solved by manikyath,
13 minutes ago, josephpwer123 said:how do i set it up tho as idk if i need to link the file in or not into the "user_jvm_args.txt" but i dont know how to link the java file to it as whenever i have tried to adjust it it never works then i have to go back to default and nothing gets changed and how do you uncomment
a line with a # at the start is a comment, removing the # 'uncomments' that line. forge's provided way to launch things includes any java arguments in that file.
it's literally made to be as easy to configure as possible, i cannot explain this beyond what is already there, because there is nothing left to explain.
