Just now, CalumA said:
can anyone of you recommend a settings guide to set all of the voltage and clock speed please. (I'm fairly new to overclocking)
What I'd do is first install msi afterburner Afterburner (msi.com) and then when you get to the clock speed setting you're going to increase that by about 40 or 50 mhz in increments as well as the memory clock speed by about 100mhz every time and after you do that once then do a stress test (like one of you're games, preferably the one that's the most intensive but even a shooter works as this is just a test for stability) and then if that's stable you can go back to msi afterburner and increase the clock speed and mem clock speed by the same increments and repeating the game testing until you can't overclock anymore
or just follow this video but what they forget to mention is about the memory clock speeds and I'd still increase those by at least 50mhz each time. You don't need to but I like to
Btw you can also undervolt which is quite easy
Follow this vid from LTT at 13:40
or this one at 2:30
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
https://linustechtips.com/topic/1537437-overclocking-help/#findComment-16179964
I would just recommend using OC scanner in afterburner, I personally tested how much further I can manually overclock compared to OC scanner and all I got was 15mhz (which is not even measureable).
https://linustechtips.com/topic/1537437-overclocking-help/#findComment-16179975
undervolting is more effective and you aren't going to get "+50% fps" as they say in this video linked above either way. more like 10%, maybe, if lucky...
when i tried oc scanner it was more or less useless,  however with undervolting i get 100 mhz+ compared to stock straight (ie 2010mhz) with much lower temps, but as said, even that isn't really boosting fps much, reason im doing this is temps simply, i hate parts running hot and with that i get around 60c on average,  which i find acceptable (compared to 70+ without the undervolt)
-Scott Manley, 2021
https://linustechtips.com/topic/1537437-overclocking-help/#findComment-16179997
that has a much bigger impact on fps anyway,  so yeah, definitely want to overclock that. the gpu itself,  nah, as said undervolting gives much better performance typically due to how nvidia boost works (its all about the temps)
-Scott Manley, 2021
https://linustechtips.com/topic/1537437-overclocking-help/#findComment-16180002
ye with my 3060 I managed to get about 2200mhz and went from 360 fps to 500. Only in rocket league tho at 1080p so the fps was already high enough
Total: £1040.95
https://linustechtips.com/topic/1537437-overclocking-help/#findComment-16180007
i tried this and everytime i scan it cancels sadly
https://linustechtips.com/topic/1537437-overclocking-help/#findComment-16180083
