Best upgrade path for current setup? 2700x/2070/B450
Solved by SorryBella,
1 minute ago, Stormseeker9 said:worth it
nope.
1 minute ago, Stormseeker9 said:would be 5800x3d
Yes and honestly that would be it for Cities, most simulator titles, and F1 series for as long as they stick to EGO. If you have stock cooler you need an aftermarket cooler but after that as long as your case is pretty well ventilated you can run it on stock settings.
