CPU Cooler screwed into backplate
Go to solution Solved by TPCEA,
7 hours ago, iGPR3 said:
Hi, I’m swapping out CPU from Intel to AMD and need to take my cooler off.
Sadly, my cooler is screwed so hard into the backplate behind my motherboard that, when I unscrew the cooler, the backplate’s screw hole spins with it. All my other screws are okay and came out without a problem, but this one is screwed so tight it moves with the backplate mounting hole. Anyone know how I can get it loose? I’ve already tried holding the backplate screw hole in place with some tweezers, but it’s too small of a gap to get a good grip
Sorry for the terrible explanation but hopefully you get the idea. Thanks!
I gather needle-nose pliers won't fit? There are specialty pliers that should fit.
https://linustechtips.com/topic/1536649-cpu-cooler-screwed-into-backplate/
I'd suggest get it to a repair shop, might want need some soldering or non conductive glue (if there is even such a thing).
Take it from me, anything half-assed might just kill your motherboard. I lost a laptop because I could not unscrew a stripped screw, and somehow I killed the laptop in the process. This was years ago tho, lesson learnt the hard way.
Occassionaly visits the forum when I have nothing to do at work.
I've been using computers since around 1978, started learning programming in 1980 on Apple IIs, started learning about hardware in 1990, ran a BBS from 1990-95, built my first Windows PC around 2000, taught myself malware removal starting in 2005 (also learned on Bleeping Computer), learned web dev starting in 2017, and I think I can fill a thimble with all that knowledge. 😉 I'm not an expert, which is why I keep investigating the answers that others give to try and improve my knowledge, so feel free to double-check the advice I give.
My phone's auto-correct is named Otto Rong.🤪😂
Quick update: managed to jam a flathead screwdriver in the backplate. The plastic that held the mounting hole to the backplate had broke and was spinning freely in there, so a screwdriver stopped it from spinning and let me unscrew it. Thanks!
