How does FSR3 work on so many GPUs?
On 9/30/2023 at 3:30 AM, jaslion said:The 5700 doesn't have any ai accelerators. The 6000 series does neither however they have dedicated ray accelerators.
So I assume it's basically a case of the architecture used happens to be compatible with full fsr 3 on the 5700 and the rx 6000 series has the architecture + dedicated cores so that might push further eventually.
This does also bring up the idea of potentially backporting full fsr 3 to older cards as it seems to be able to run on non ai and non rt core dedicated cards.
Amd wrote the software as an async compute task, it doesn't have any ai processes involved. It's in short, a system of combining frames, nvidia includes hardware to accelerate the process, AMD on the other hand wrote code, that hypothetically can use some of the rendering time on some of the hardware that's not being utilized to complete the process. There are advantages to both methods.
