Hi guys,
Usually quite good at this but I have a Hyte Y60 build where I can't seem to get the drain valve positioned so the loop drains properly.
See pic below:
Pump / Res > Barrow Flow Meter > GPU > EK120 > CPU > EK360 > EK240 > Back to Pump / Res.
As the pipe exists the EK240 and loops back to the top fill port of the Reservoir there's a T-Piece at low level where the ball-valve connects to.
When I open the valve and let air in by opening the other fill-port on the reservoir, only the liquid in the res comes out. I can open the additional fill port at the top of X240M Rad but that doesn't help either.
I end up having to rock the case around to try and get enough out so that at some point I can fit a length of flexi to a component and start blowing.
Any help / suggestions would be greatly appreciated.
Living Room PC - Lian-Li O11 XL Evo - MSI X870 Tomahawk Mobo - AMD 9800X3D - 32GB DDR5 Ram - RTX 4090 - 2TB Samsung 990Pro NVMe - Antec 1200w PSU - Dual Custom Loop Cooling - GPU cooled with EK Quantum Surface S240 + EK Quantum Surface P360M X-Flow Rads - CPU cooled with EK Quantum Surface X360M Rad
Bedroom PC - Hyte Y60 - Intel Core i5 13600k - MSI Pro-A Wifi Z790 Mobo DDR5 - 32GB Ram - RTX 5070ti - 1TB Samsung 990Pro NVMe - Corsair HX1200i PSU - CPU + GPU cooled with Hyte Y60 Corner Distro Plate - EK Coolstream S120 + EK Quantum Surface S360 + EK Quantum Surface X240M
Extension PC - Lian Li o11 Dynamic - Intel Core i9 9900k - MSI Meg Ace Z390 Mobo - 16GB Ram - RTX 3080ti - 256GB Samsung NVMe - Corsair AX850 PSU - CPU + GPU cooled with dual EKWB 360 Rads + G1 side EKWB distro plate.
Office PC - Thermaltake Tower 100 - Intel Core i7 8086K - Gbyte Z390 I Aorus Pro Wifi Mobo - 16GB Ram - iGPU - 256GB Samsung NVMe - EVGA B5 850W PSU - CPU cooled with dual EK Quantum Surface P120M Rads + Barrow 3-in-1 Block, Res & Pump.
Spare - Corsair 250D - Intel Core i7 8700k - Gbyte Z390 I Aorus Pro Wifi Mobo - 16GB Ram - GTX 980ti - 256GB Samsung NVMe - BeQuiet P11 750 PSU - CPU cooled with EK Coolstream S240 + S120 Rads + EK Pump / Res Combo
Annex - Corsair 280X - Intel Core i7 4790k - Asrock H97M ITX Mobo  - 16GB Ram - EVGA GTX 1080ti - Corsair SFXL600 PSU - CPU + GPU cooled with triple EK Coolstream S240s + EK Pump / Res Combo
NAS PC - Fractal Node 804 - Intel Core i7 3770k - Asus P8Z77-M Mobo - 16GB Ram - MSI GTX 1660 Ventus - Corsair AX850 PSU - Unraid 21TB Storage Server
Living Room AV Setup 5.1.4 - Nvidia Shield - Yamaha RX-A6A - 2 x B&W CM9s2 - 2 x Monitor Audio FX Silvers - 4 x B&W CCM665s - B&W CMCs2 - SVS SB13 Ultra - LG OLED65C1
Extension AV Setup - Sonos ARC + Sub (Gen 3) - LG OLED65C6V + Sonos Amp - 5 x Monitor Audio C265s
Bedroom AV Setup - Yamaha WXC-50 - 2 x B&W CM1s - Rel Quake - LG OLED42C2.
https://linustechtips.com/topic/1533530-loop-draining-problems/
The drain valve is about as low as the liquid in the GPU block which has to go up and down a several times before exiting. It looks like you will have to keep tipping it around or maybe try finding a way to rest it on its side so the case ends up having the drain downward with the help of gravity to release the liquid from the other components.
CPU: AMD Ryzen 9 3950X   Motherboard: MSI X570 Gaming Edge Wifi   Case: Deepcool Maxtrexx 70   GPU: RTX 3090   RAM: Corsair Vengeance LPX 3x16GB 3200 MHz   PSU: Super Flower 850W
https://linustechtips.com/topic/1533530-loop-draining-problems/#findComment-16153901
Yeh, its a total pain.
On most of my other builds, its just a matter of open the drain valve and then open the fill port on the res or another point around the loop and it pretty much drains entirely.
This is the complete opposite. If I get a bit more time, I'm gonna pop a few air valves at choice points around the loop and see if that helps.
Thanks guys.
C
https://linustechtips.com/topic/1533530-loop-draining-problems/#findComment-16155057
It's why I just stick with soft tubing with quick disconnects along, and 1 or 2 drain valves. I also don't bother using a reservoir so there is less liquid to drain making things easier.
https://linustechtips.com/topic/1533530-loop-draining-problems/#findComment-16155497
Once you drain from certain tubes you can really just remove it from a fitting and then take a data vac to the rest of the loop to blow the coolant out through the drain port.
I do this on my O11D rig with hard tubing as well as my open test bench with soft tubing. Quick disconnect fittings would help with that as well, but never heard of such a thing for hard tubing.
Zen 3 Daily Rig (2022 - Present): AMD Ryzen 9 5900X + Optimus Foundations AM4 | Nvidia RTX 3080 Ti FE + Alphacool Eisblock 3080 FE | G.Skill Trident Z Neo 32GB DDR4-3600 (@3733 c14) | ASUS Crosshair VIII Dark Hero | 2x Samsung 970 Evo Plus 2TB | Crucial MX500 1TB | Corsair RM1000x | Lian Li O11 Dynamic | LG 48" C1 | EK Quantum Kinetic TBE 200 w/ D5 | HWLabs GTX360 and GTS360 | Bitspower True Brass 14mm | Corsair 14mm White PMMA | ModMyMods Mod Water Clear | 9x BeQuiet Silent Wings 3 120mm PWM High Speed | Aquacomputer Highflow NEXT | Aquacomputer Octo
Test Bench:
CPUs: Intel Core 2 Duo E8400, Core i5-2400, Core i7-4790K, Core i9-10900K, Core i3-13100, Core i9-13900KS
Motherboards: ASUS Z97-Deluxe, EVGA Z490 Dark, EVGA Z790 Dark Kingpin
GPUs: GTX 275 (RIP), 2x GTX 560, GTX 570, 2x GTX 650 Ti Boost, GTX 980, Titan X (Maxwell), x2 HD 6850
Bench: Cooler Master Masterframe 700 (bench mode)
Cooling: Heatkiller IV Pro Pure Copper | Koolance GPU-210 | HWLabs L-Series 360 | XSPC EX360 | Aquacomputer D5 | Bitspower Water Tank Z-Multi 250 | Monsoon Free Center Compressions | Mayhems UltraClear | 9x Arctic P12 120mm PWM PST
https://linustechtips.com/topic/1533530-loop-draining-problems/#findComment-16159854
Yeh, that's I need to do with this loop. The strange thing is, I don't normally have an issue with any of my other builds. Its normally as easy as open the drain port, pop the air cork and let the fluid flow. There's always a little left over which I need to blow out but most of it comes out in the first shot. In this Hyte build, its realistically only the liquid on the res that drains.
I've  got an o11 build as well. I use the side distro plate which causes a similar issue as it only really drains itself although it is a bit easier to pop a fitting and screw in a bit of flexy and use the blow technique.
Its not a total disaster as I'm gonna get the side distro plate for the Hyte when its available in the UK.
https://linustechtips.com/topic/1533530-loop-draining-problems/#findComment-16160408
Not a fan of distribution blocks/plates. They don't hold as much coolant as a res and they are impossible to clean. Plus add quite a bit of restrictiveness to the loop.
Test Bench:
https://linustechtips.com/topic/1533530-loop-draining-problems/#findComment-16160846
  • 2 weeks later...
There's a YouTuber named Steve Mould who did some videos about this kind of challenge although not specific to computers that might be interesting for you.
I've been using computers since around 1978, started learning programming in 1980 on Apple IIs, started learning about hardware in 1990, ran a BBS from 1990-95, built my first Windows PC around 2000, taught myself malware removal starting in 2005 (also learned on Bleeping Computer), learned web dev starting in 2017, and I think I can fill a thimble with all that knowledge. 😉 I'm not an expert, which is why I keep investigating the answers that others give to try and improve my knowledge, so feel free to double-check the advice I give.
My phone's auto-correct is named Otto Rong.🤪😂
https://linustechtips.com/topic/1533530-loop-draining-problems/#findComment-16169385
Thanks guys.
C
You can also attach some hose to a higher point and blow in it
https://linustechtips.com/topic/1533530-loop-draining-problems/#findComment-16169505
I think the main issue I have, is this is the only build I ever have drain problems with and I also have flow rate issues with it, at least as far as I can tell.
I have a Thermaltake Tower 500 build that I managed to botch for a dual loop setup and both of my Barrorch flow meters report in or around 8L/m per loop. In my Hyte Y60 the Flow meter reports 1.2L/m and fluctuates wildly down to 0.5 - 1.2.
Maybe there's a more serious issue in the loop that's causing a vacuum as @jaslion suggested.
I just don't have any thermal issues and filling the loop is easy, draining the damn thing is a total faff.
https://linustechtips.com/topic/1533530-loop-draining-problems/#findComment-16169847
On 9/29/2023 at 5:41 AM, ChrisLoudon said:
Hi guys,
See pic below:
Looking at it, you can see the problem. The majority is not part of the pipe "circuit" that you created is at or a bit above the level of the drain, and the drain isn't connected to anything other than the res. Opening the fill port only releases the res fluid. I agree that you need other release points but, honestly, you also would be better off redesigning the whole thing so that not only is the drain at the bottom but it is connected to all discrete parts of the loop,  and maybe a high point valve connected to everything where you can open it to release the fluid.
https://linustechtips.com/topic/1533530-loop-draining-problems/#findComment-16169866
Thanks for the info buddy.
The drain port is connected to more than the the res. You can't quite see it but the drain valve takes a 90 right just behind the flow meter and connects into one of those 3 / 4 way cubes. The side radiator flows out at low level behind the res then into that cube. With the drain valve closed, the fluid then flows up then into the res.
One thing I haven't tried is keeping the fill port on the reservoir closed and popping the additional port on top of the side rad instead. Its a little higher up the order.
https://linustechtips.com/topic/1533530-loop-draining-problems/#findComment-16169876
Ah, indeed I couldn't see all that. So the pipe out of the top of the res feeds to...?
So what I can see is this: CPU to back rad to GPU to res to top rad to CPU. Did I get it? Can you add in the invisible stuff?
https://linustechtips.com/topic/1533530-loop-draining-problems/#findComment-16169936
So the pipe into the top of the res is the final 'input' completing the loop.
Loop order is as follows:
Pump / Res > Barrow Flow Meter > GPU > Coolstream S120 (rear) > CPU > Quantum Surface S360 (top) > Quantum Surface X240M (side) > T-Splitter to Drain > Back to Res.
The extender you see pointing up on the res is an attempt at an additional drain port (original blue fluid pic).
The X240M is oriented with the fill and drain ports at low level. The pipe you can see in the pic attached below is the fill with the drain just out of sight behind. It then loops back up and into the res as seen in the other pic but has T-junction that goes to the drain valve.
https://linustechtips.com/topic/1533530-loop-draining-problems/#findComment-16169957
