iFi Zen Can with DT770 Pro 80Ohm for my turntable
Solved by ImWilly,
1 hour ago, Leychee said:Topping DX1 I bought didn't work, I decided to go for an iFi Zen Can. Will the sound quality be any good with this setup?
Unless you got a golden ear, chances are you won't notice the difference
1 hour ago, Leychee said:Do I need a 3.5 to 4.4 adapter to plug my headphones into the amp? Or is the included 6.3 adapter enough?
It's quite a mixed bag, in my opinion, using unbalanced (3.5mm & 6.3mm / quarter inch) and balanced (4.4mm) doesn't really give that many improvements
Some would claim that balanced sounds better, but I can't vouch for that
So, as long as it works, I say it's fine. Enjoy your hi-fi setup
