Glorious Model O (Wired) "lagging" at 1000hz polling rate?
Hi guys!
This have been a problem I've had since I got this mouse, probably like 7-8 months ago.
When I first got this mouse, I noticed I could put the Polling rate at 1000hz, which is pretty good, so I did put my polling rate at this level.
But, the thing is, that my mouse has some "lags" when using this polling rate. Indeed, when moving my mouse around with my polling rate level at 1000hz, for some reason, my mouse lags. I'll put some videos below so you guys can notice what's the problem and probably tell me how to fix it.
This issue crops up occasionally, and there is always a different solution for everyone. I would check if the mouse behaves alright on a different machine to ensure it's not a hardware issue.
There is already a thread on this board about this exact issue. I would jump through some of the links on the thread to see if any of them can help you:
