Running out of ideas with weird artifacting issue
25 minutes ago, Rainbrew said:I was under the impression that with DSC you can get 240hz 1440p with 10bit colour and HDR. I'm not sure I'll be able to test my PC on another display with DSC to verify if it's the GPU that's at fault here though so here's hoping there's a magic setting I missed somewhere .
Hmm, I'm not sure about the ability to achieve those settings, but the problem only presents itself in the BIOS and when entering Windows, right?
If so, it could be that the BIOS does not support 10 bit colour and the graphics are not actually an issue, but just a distortion, whereas since CSM's software is so basic, it doesn't even try to display anything with 10bit colour, hence no distortion appears.
I don't know when Windows fully enables the hardware/driver support when you login, but it could be the same thing.
25 minutes ago, Rainbrew said:I'll try to find some settings online that maybe I need to play around with to get stuff running.
Yeah, though it might be that you can't, since 10 bit colour and HDR are still pretty new, so I wonder if these are just teething problems, that will work themselves out over time?
25 minutes ago, Rainbrew said:I'm running the latest game drivers, I've never touched the studio ones.
You could give them a try, since they may be tested more thoroughly for these settings?
