Hi there everyone I don’t know if this is the correct forum to post in as I couldn’t find a smart home forum. I was just looking at the homey pro home hub as I wanted to go a bit more advanced with my automations with out using home assistant I was looking on homey’s little app market place and I couldn’t find the apps I need for my product the products I have are nest smoke alarms google home hubs and Yale looks along with some Reolink cameras and Phillips hue. I can see they have a app for Phillips hue but now the question is do I still need Phillips hue hub or not if some one can tell me if all of my de ices work that would be much appreciated
https://linustechtips.com/topic/1531979-homey-pro-devices-compatible/
Why not use home assistant..?
57 minutes ago, Isher said:
I don’t want to go to advanced
Home assistant is very, very simple. And there are guides ALL over YouTube and forums explaining all of the basics. I would argue it’s the most simple solution due to all of the easily accessible info and examples on YouTube.
It can be very advanced, but it also is exceedingly simple if all you want to do it set up a few integrations. I have been using it for years, it’s become very simple to use over the last 1-2 years.
