Computer Time Out and Lock Issue
Hello, I am having an issue with my computer's screen turning off (but the computer not going to sleep), and my computer locking, instead of it staying unlocked with the screen off like it usually does. My computer would only lock if it were to go to sleep but never when the screens would turn off and the computer was still on. This issue started happening after I was messing around in the screen saver settings. I no longer have a screen saver on but I can't figure out how to fix this problem and revert back to how it was.
https://linustechtips.com/topic/1530921-computer-time-out-and-lock-issue/
Check out power options assuming you are on windows.
Control Panel\Hardware and Sound\Power Options\Edit Plan Settings
My PC Specs: (expand to view)
Main Gaming Machine
CPU:  Intel Core i7-14700K
CPU Cooler: Deepcool LT720
Motherboard: MSI PRO Z790-P WIFI
Memory: G.Skill Trident Z5 RGB 32 GB (2 x 16 GB) DDR5-6400
Storage 1: Samsung 990 Pro 2 TB
Storage 2: Crucial P3 Plus 4 TB
Video Card: EVGA XC3 ULTRA GAMING GeForce RTX 3080 10GB
Power Supply: Corsair RM850 850W
Case: Corsair 7000D Airflow
Case Fan 140mm: Noctua A14 PWM 82.5 CFM 140 mm (x7)
Monitor Main: MSI G274QPF-QD 27.0" 2560 x 1440 170 Hz
Monitor Vertical: Asus VA27EHE 27.0" 1920x1080 75 Hz
