Fan Configuration Question
Go to solution Solved by CommanderAlex,
Place the 3 Cooler Master MF120 Halo Fans at the front of case for intake and one exhaust out the back, with AIO being in intake blowing up so fans pulling air in from the front.
I’m helping someone with a build and would like some advice on the configuration of the fan layout. For reference:
Ryzen 7 7800X3D
RX 7900 XT
NZXT Kraken 240 AIO
Cooler Master Mesh 300 case
The current design is to put to MF 120 fans in the front and one in the back with the NZXT AIO on the top. My question is which should intake vs exhaust.
Thanks!
https://linustechtips.com/topic/1530837-fan-configuration-question/
CPU Cooler Tier List  || Motherboard VRMs Tier List || Motherboard Beep & POST Codes || Graphics Card Tier List || PSU Tier List
Main System Specifications:
CPU: AMD Ryzen 9 5950X ||  CPU Cooler: Noctua NH-D15 Air Cooler ||  RAM: Corsair Vengeance LPX 32GB(4x8GB) DDR4-3600 CL18  ||  Mobo: ASUS ROG Crosshair VIII Dark Hero X570  ||  SSD: Samsung 970 EVO 1TB M.2-2280 Boot Drive/Some Games)  ||  HDD: 2X Western Digital Caviar Blue 1TB(Game Drive)  ||  GPU: ASUS TUF Gaming RX 6900XT  ||  PSU: EVGA P2 1600W  ||  Case: Corsair 5000D Airflow  ||  Mouse: Logitech G502 Hero SE RGB  ||  Keyboard: Logitech G513 Carbon RGB with GX Blue Clicky Switches  ||  Mouse Pad: MAINGEAR ASSIST XL ||  Monitor: ASUS TUF Gaming VG34VQL1B 34"
I would be inclined to put the AIO on the front as intake, one fan on the back and 2 on the top (rear) as exhaust. That will give you the best temps in many cases. However, the best way to know is to try.
I've been using computers since around 1978, started learning programming in 1980 on Apple IIs, started learning about hardware in 1990, ran a BBS from 1990-95, built my first Windows PC around 2000, taught myself malware removal starting in 2005 (also learned on Bleeping Computer), learned web dev starting in 2017, and I think I can fill a thimble with all that knowledge. 😉 I'm not an expert, which is why I keep investigating the answers that others give to try and improve my knowledge, so feel free to double-check the advice I give.
My phone's auto-correct is named Otto Rong.🤪😂
