Can I Use Cooler Master ML240L V2 for R9 5900X
Solved by filpo,
6 minutes ago, _GLADIATOR said:I'm planning on upgrading my CPU with r9 5900x, so I'm just wandering if my existing cooler (CM ML240L V2) will be enough or not?
also if its not enough and i do need to upgrade cooler then pls suggest me an air cooler compatible with MSI MAG B550M MORTAR and NZXT H510 case.
Thanks in advance...
Try it with a stress test (like cinebench r23) and if it overheats then get something like the arctic liquid freezer ii 280
It should be enough but it's not certain
