Hey, everyone!
I've been having this issue for a while. As you can see in this video, whenever I pull the left analog stick up, it process it as walking, instead of running as it should. However, if pull it to the sides or down, it works properly.
Sometimes it works fine for a few seconds if I pull it really hard.
Do you know how is this called or how to fix it?
OS Windows 11
CPU AMD Ryzen 7 3700X (AM4)
MOBO ASUS ROG STRIX B450-F GAMING II
RAM Patriot V4s Viper Steel RGB DDR4 8 GB x4 (32 GB) 3200 MHz)
GPU NVIDIA GeForce GTX 1660 6 GB GDDR5
SDD Samsung 960 EVO 250 GB (MVME) // Adata Su650 480 GB (SATA)
HDD Western Digital WD20EZRZ 2 TB 5400 RPM // TOSHIBA DT01ACA050 500 GB 7200 RPM
PSU NZXT Hale 82 V2 550 W 80+ Bronze
https://linustechtips.com/topic/1530394-xbox-360-controller-wont-work-properly/
