Hello,
R7 Am5  7700x  Deepcool AIO LS520 240mm
32gb g skill 6000mghz
TUF 3080ti
PSU:Rm850x
I have been using Hwinfo64 to monitor temps and there are times where the maximum column will hit 90 or just high 80s.
the average column never breaks 55c
the max column just makes me nervous and this is my second rig and first am5.  Anyone that can educate me would be greatly appreciated.
Thanks all!
https://linustechtips.com/topic/1529823-hwinfo64-temps-issue/
1 hour ago, danb8621 said:
Hello,
TUF 3080ti
PSU:Rm850x
Thanks all!
Try to check in Ryzen Master and Aida64 if there are sudden spikes in temps.
Always set pump speed to full speed from Bios.
CPU: Ryzen 7 5700X Undervolted  Motherboard: B550 Aorus Elite V2 Rev1.2 RAM: G.Skill TridentZ Neo 3600Mhz CL16 32gb
GPU: MSI Mech 2X RX6600 8GB Cooler: ProLab Design AI360 LC AIO Storage: WD SN770 500gb + Sn550 1Tb + MX500 1Tb + 1TB HDD
PSU: Antec EAG Pro 750 80+G Case: Deepcool CG580 WH Monitor: Benq Mobiuz EX2510 144Hz
Mouse: G Pro Wireless Keyboard: Corsair K68 RGB Cherry MX Red Speakers: Creative Pebble V2
https://linustechtips.com/topic/1529823-hwinfo64-temps-issue/#findComment-16124815
Weak cooling is the problem. Either with the way you have your system setup, or the actual performance of the cooler is weak.
AMD R9 9900X | Thermalright FW Pro Black, 3x TL-B12E | Asus Strix X670E -F | 64GB G.Skill 6000C26
Zotac 4070 Ti Trinity OC | WD SN850, SN850X, 2x SN770 | Seasonic Vertex GX-1000 | ProArt PA602
Adcom GFP-345, Adcom GFA-555, S.M.S.L D1+PS100, Cerwin-Vega! CLSC-15, Monster HDP-1800
https://linustechtips.com/topic/1529823-hwinfo64-temps-issue/#findComment-16124818
Modern chips run hot because they boost until they got a thermal limit, I don't see this being an issue tbh
If someone has helped you out on the forum don't forget to give them a reaction to say thank you!
The only true wisdom is in knowing you know nothing. - Socrates
Please put as much effort into your question as you expect me to put into answering it.
https://linustechtips.com/topic/1529823-hwinfo64-temps-issue/#findComment-16125026
