2 minutes ago, Sawa Takahashi said:
If the performance is not good, it is possible that the chip uses almost no power.
Did you check in MSI Afterburner if everything is at it should ?
Yes I did I even set the power percent to 110. Should I try flashing a different 960 bios?
https://linustechtips.com/topic/1529671-gtx-960-power-problem/#findComment-16123709
Are you running the stock BIOS ? I would not flash an alternative BIOS because the stock BIOS is supposed to work just fine.
Sometimes Windows updates or driver updates break the functionallity of older hardware. You can try uninstalling the last few updates and see if it fixes anything.
https://linustechtips.com/topic/1529671-gtx-960-power-problem/#findComment-16123713
I am. Could the bios be corrupted?
https://linustechtips.com/topic/1529671-gtx-960-power-problem/#findComment-16123714
