Build Plan Criticism
Your initial build wasn't bad, but i just went and beefed it up a bit:
CPU: AMD Ryzen 7 7800X3D 4.2 GHz 8-Core Processor ($384.00 @ Newegg)
CPU Cooler: ARCTIC Liquid Freezer II 360 56.3 CFM Liquid CPU Cooler ($115.19 @ Amazon)
Motherboard: Gigabyte B650M AORUS ELITE AX Micro ATX AM5 Motherboard ($179.99 @ Amazon)
Memory: G.Skill Flare X5 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory ($96.99 @ Amazon)
Storage: Crucial P5 Plus 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive ($87.99 @ Newegg)
Video Card: Sapphire NITRO+ Radeon RX 7900 XTX 24 GB Video Card ($1019.99 @ Newegg)
Case: Phanteks Eclipse G360A ATX Mid Tower Case ($89.99 @ Newegg)
Power Supply: Corsair RM1000x (2021) 1000 W 80+ Gold Certified Fully Modular ATX Power Supply ($169.99 @ Amazon)
Total: $2144.13
Generated by PCPartPicker 2023-08-31 13:17 EDT-0400
The changes - the cooler is now the best 360 AIO on the market. As cooler as you can keep the 7800X3D, the better.
Got you a tier higher motherboard, could go the X670, but no point really
The memory is probably the 2nd most important thing after the GPU. The sweet spot for Ryzen 7000 is 6000MHz CL30. This one has EXPO, which improves a bit the stability over XMP on AMD platforms
Faster storage with DRAM.
The best air cooled 7900XTX on the market currently is Sapphire's NITRO+. With the 6000 series used to be Red DEvil, but now NITRO+ is better in terms of performance AND thermals.
A much better case with 3x120 front fans included. Just install the LF II 360 on top as exhaust and it all will be perfect.
Upgraded the PSU to 1000W so you don't have to ever worry about instabilities due to transient spikes or stuff like that. It will take everything this hardware can throw at it. You can peacefully OC everything as much as it allows.
