[PHP] Pastebin Script without using a DB
So I was messing around the other day because I was bored and I felt like making an addition to my site.
also I know this isn't advanced by any means and I know there's a lot of things in it that could be better / proofed but it does work.
So I decided why not make and release a php pastebin without a DB.
How it works?
It just uses fwrite(); with regular "files".
script shit:
http://pastebin.com/Ye2zRJ0A
i want to die
https://linustechtips.com/topic/152898-php-pastebin-script-without-using-a-db/
Why are you using mt_rand() and not a proper UUID. Even a timestamp would be better than mt_rand().
I actually made a random string generator "rand.php" but I didn't include it in that paste, because I made the paste a couple days ago and felt like sharing it.
In rand.php it makes the string and checks the writes folder for an existing string.
i want to die
But any randomness is silly. There is always a chance it will colide with an existing value, and just waste time creating a new value.
 http://www.php.net/manual/en/function.uniqid.php should be used instead.
a random string generator that checks if it is already in use is what I use. There's no chance of colliding values. Thanks for the link to documentation on something I don't need to use though.
i want to die
