Please help...anyone...
I have been running into a problem on my PC that I think is connected to my GPU.
Since around the time of the Diablo 4 launch, I have been getting this problem where both my screens go black and the GPU fans blast at what feels like 200%.
I have to restart the PC manually for the problem to go away.
I don't know why this is happening as there is no error popping up.
This has been happening in all my games, not just Diablo 4.
This is what I have tried:
  1. Update GPU drivers: This doesn't make it better, it actually feels like this is making it worse. Every time I have updated the drivers the "crash" has happened.
  2. Unplugging the second monitor makes no difference
  3. Lowering the graphic options in-game makes no difference.
  4. I have monitored the temps to make sure that's not the problem.
  5. I have tried to use the MSI After Burner monitoring function...to no avail...
Is there a different software that monitors and records better than Afterburner?
I don't know what to do anymore.
I am adding a DxDiag file to this post to serve as a description of my PC and hardware, please let me know if you need more info.
Thanks
Aku
DxDiag.txt
https://linustechtips.com/topic/1528337-gpu-troubleshooting-help/
Which PSU?
Latest Bios?
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
Check GPU temps and clocks while gaming, could be overheating or core dropping from too high clock
And a 3080 is a hot chip
Did you do any Afterburner tweaking like undervolting ?
this is a dumb question but what's the psu situation in your system? cause i have hardware that's a lot worse than yours but used to run into a similar problem. i'd play a game and i think the card would have a power spike or something but it'd be a black screen, completely unresponsive pc and gpu fans would go crazy. but i was hooking up a 150W card to a 295W PSU via a SATA Power to PCIe adapter so i kinda expected it.
Use DDU to fully delete all Graphics drivers then reinstall of official website.
My First PC
CPU: Ryzen 5 5600x
Cooler: Asus TUF Gaming LC240
Motherboard: Asus ROG Strix B550-f gaming
RAM: 4x8 GB Corsair Vengeance RS (3200 MHz, CL16)
Storage: 1tb Samsung 980 Pro
Graphics Card: Asus Dual RTX 2060 OC
Case: Deepcool Matrexx 50
Power Supply: Corsair RM650x
Headset: Razer Blackshark V2
Keyboard: Corsair K70 Pro Mini (Speed Silver switches)
Mouse: Razer Viper Mini
Only changes I have made is I sold the 2060 for $235 AUD and bought a Powercolor Red Devil 6700 XT for $400 second hand (it was barely used, think I scored a deal on Ebay with that).
I love Photography (Using a Canon 60D)
Love F1, my favourite team is Ferrari and my favourite driver is Leclerc
Thanks to everyone who replied to my message.
21 hours ago, 191x7 said:
Which PSU?
Latest Bios?
PSU is a 700w unit
I updated my Bios this morning, to test if this will help. I will revert back if there is any changes from this.
I have undervolted my card in the last year to try and bring the temps down. Here in South Africa, it gets quite hot in summer time so I had to try and reduce the temps. Below is a screenshot of the after-burner window, 100% honesty... I had no idea what I was doing so I followed a YT video...
Trying this now, I will revert back if there are any changes from this.
17 hours ago, Whatisthis said:
3080 gpus have a flaw that Diablo 4 exposes that can cause damage to the cards. Sounds like this may have happened to your card.
Test the card in another system to verify. Check if your warranty is still valid and RMA if needed.
I have known about this for some time, I really hope that this isn't my problem.
Thank you for all the replies!
Okay..so none of the above worked. 2min into Baldur's Gate and the crash happened.
I don't know if I can upload the hardwaremonitor.html file from Afterburner here so here is a screenshot of the recording. There doesn't seem to be any spike on the graphs when the crash happened, only a drop to 0 on everything.
PS. I made sure the undervolting were disabled when I tried playing again.
PSU is a 700w unit
I will ask again. Which PSU?
PSU is a 700w unit
Undervolt can make some games cash, I've had crashes in Unity games especially when I had an undervolted 3080
Yours is low clock but low voltage as well
Drop it and recheck
I need to unplug everything from the case to remove the PSU to see the exact name, I will not be doing that atm.
Drop it and recheck
I turned it off completely this morning after reinstalling the drivers and updating the BIOS...still the crash happens.
You can take a photo and I might be able to recognize it.
Which exact 3080 is it? Maybe there's a vBios update for the card...
I switched my 3080 with my wife's 2070 Super, no crashes yet...it seems that the card might be damaged.
The card won't work in her machine as she has a smaller PSU so I will need to send the card to a shop to be tested...
Wel then it's either a PSU issue (Op crashing on a power spike) or some GPU clock crash
Test with a gimped max clock (say 1600MHz)
