7 minutes ago, raid25885 said:
How can I find out the TDP for AIO coolers ? The manufacturers' sites don't list them, such as ASUS, Corsair, MSI. How will I know if AIO cooler can handle high-demand CPUs like 13th gen i7 or i9 ?
Look at reviews, TDP ratings are a lie across the board anyway
If someone has helped you out on the forum don't forget to give them a reaction to say thank you!
The only true wisdom is in knowing you know nothing. - Socrates
Please put as much effort into your question as you expect me to put into answering it.
https://linustechtips.com/topic/1528258-aio-cooler-tdp/#findComment-16111446
My cooler is rated for 275w, and I can give it 245w from a 105w CPU 😄
AMD R9 9900X | Thermalright FW Pro Black, 3x TL-B12E | Asus Strix X670E -F | 64GB G.Skill 6000C26
Zotac 4070 Ti Trinity OC | WD SN850, SN850X, 2x SN770 | Seasonic Vertex GX-1000 | ProArt PA602
Adcom GFP-345, Adcom GFA-555, S.M.S.L D1+PS100, Cerwin-Vega! CLSC-15, Monster HDP-1800
https://linustechtips.com/topic/1528258-aio-cooler-tdp/#findComment-16111464
It's important to note that the difference in temp from the air and heatsink/fluid/whatever changes how much heat can be dissipated so it really isn't all that simple
https://linustechtips.com/topic/1528258-aio-cooler-tdp/#findComment-16111468
Especially as when on an intake its likely to cool better than as an exhaust where its heating up from the GPU exhaust too.
Then there's the whole "room temperature" to take into account.
https://linustechtips.com/topic/1528258-aio-cooler-tdp/#findComment-16111501
4 minutes ago, raid25885 said:
So AIOs are more complicated than air coolers ...... ?
Air cooling is complicated..
But it doesn't have to be.
https://linustechtips.com/topic/1528258-aio-cooler-tdp/#findComment-16111522
Some people have a nice AIO but cant cool their CPU...
Some people can get better temps with air than an AIO..
Its complicated 😄
https://linustechtips.com/topic/1528258-aio-cooler-tdp/#findComment-16117697
