9 minutes ago, Domaboi said:
can someone find me a pc on caseking.de
my budget: 2600 euro
i will use it mostly for gaming squad
can someone pls TY
What resolution is your monitor or do you need a monitor included in your budget and out of curiosity are you located in Germany and if not what country?
https://linustechtips.com/topic/1527094-pc-parts-list/#findComment-16099097
Dont need a monitor just the pc already built my grandpa lives in germany so yea
https://linustechtips.com/topic/1527094-pc-parts-list/#findComment-16099174
if you play any first person shooter games such as BF, CoD, etc or any demanding AAA games I would seriously recommend 1440P resolution so that you can maintain a decent amount of frames per second for a more fluid gameplay.
https://www.caseking.de/lian-li-lancool-216-e-atx-gehaeuse-midi-tower-schwarz-geli-924.html
Lian Li LANCOOL 216 ATX Mid Tower Case €99,90
https://www.caseking.de/msi-mpg-a850g-pcie5-netzteil-80-plus-gold-vollmodular-atx-3.0-pcie-5.0-850-watt-nems-003.html
MSI MPG A850G PCIE5 850W 80+ Gold Modular, ATX 3.0 Power Supply €134.90
https://www.caseking.de/msi-pro-b760-p-wifi-ddr4-intel-b760-mainboard-sockel-1700-ddr4-mbmc-529.html
MSI Pro B760-P WiFi DDR4 €159,90
https://www.caseking.de/intel-core-i7-13700f-2-10-ghz-raptor-lake-sockel-1700-boxed-hpit-792.html
Intel Core i7-13700F €385,95
https://www.caseking.de/deepcool-ag620-cpu-kuehler-120mm-schwarz-cpdc-010.html
Deepcool AG620 Dual Tower CPU Cooler €54,90
https://www.caseking.de/corsair-vengeance-ddr5-6000-xmp-3.0-cl36-32-gb-dual-kit-schwarz-mecs-551.html
Corsair Vengeance DDR5-6000 32GB (2x16GB) CL36 €107,90
https://www.caseking.de/crucial-p5-plus-nvme-ssd-pcie-4.0-m.2-typ-2280-2-tb-sscc-093.html
Crucial P5 Plus 2TB M.2 NVMe PCIe 4.0 SSD €116,90
https://www.caseking.de/asus-geforce-rtx-4080-tuf-16g-16384-mb-gddr6x-gcas-484.html
ASUS GeForce RTX 4080 TUF 16GB Graphics Card €1.299,00
Total: €2359.35
https://www.caseking.de/asus-tuf-gaming-vg27aq1a-68-5-cm-27-zoll-170hz-g-sync-compatible-ips-dp-2xhdmi-tfas-230.html
ASUS TUF Gaming VG27AQ1A 170Hz G-SYNC Compatible IPS Gaming Monitor €309.00
https://www.asus.com/us/displays-desktops/monitors/tuf-gaming/tuf-gaming-vg27aq1a/
A better look at those components.
https://lian-li.com/product/lancool-216/
https://www.msi.com/Power-Supply/MPG-A850G-PCIE5
https://www.msi.com/Motherboard/PRO-B760-P-WIFI-DDR4
https://www.intel.com/content/www/us/en/products/sku/230491/intel-core-i713700f-processor-30m-cache-up-to-5-20-ghz/specifications.html
https://www.deepcool.com/products/Cooling/cpuaircoolers/GAMMAXX-AG620-Dual-Tower-CPU-Cooler-1700-AM5/2022/15900.shtml
https://www.crucial.com/ssd/p5-plus/CT2000P5PSSD8
https://www.asus.com/motherboards-components/graphics-cards/tuf-gaming/tuf-rtx4080-16g-gaming/
https://linustechtips.com/topic/1527094-pc-parts-list/#findComment-16099286
Total: €2359.35
hii tnx for your help i play a lot of squad massive map first person shooter do you tink it will get good fps and also play rainbow 6 sige
https://linustechtips.com/topic/1527094-pc-parts-list/#findComment-16099292
Total: €2359.35
do you think water cooled pc will be better can you send one with water cooled pleas
https://linustechtips.com/topic/1527094-pc-parts-list/#findComment-16099296
Most all your professional gamers,Youtubers, Twitch, etc .. who plays first person shooter games play at 1440P so that they can maintain at least a average of 150 FPS.
https://linustechtips.com/topic/1527094-pc-parts-list/#findComment-16099301
No need for an AIO for that cpu. A dual tower cpu cooler for that cpu will work just fine.  If you have any plans on streaming and / or video editing then change out that cpu I posted with this one.
https://www.caseking.de/intel-core-i7-13700-2-10-ghz-raptor-lake-sockel-1700-boxed-hpit-791.html
https://ark.intel.com/content/www/us/en/ark/products/230490/intel-core-i713700-processor-30m-cache-up-to-5-20-ghz.html
https://linustechtips.com/topic/1527094-pc-parts-list/#findComment-16099309
Tnx and one more question can you change the motherboard to better one couse i want to upgrade later also that suports ddr5
https://linustechtips.com/topic/1527094-pc-parts-list/#findComment-16099319
That motherboard I posted will support the soon to be released Rocket Lake refresh cpu's. If you want a board with PCIe 5.0 and 4080 audio codec then look at this board.
https://www.caseking.de/msi-pro-z790-a-wifi-intel-z790-mainboard-sockel-1700-ddr5-mbmc-510.html
https://www.msi.com/Motherboard/PRO-Z790-A-WIFI
https://linustechtips.com/topic/1527094-pc-parts-list/#findComment-16099344
Just hear caseking is better from others
Never had problems with mindfactory and a lot of the time they are just cheaper, especially with their "mindstar"-offers you can get RX6900XT/6950XTs for under 600 € every few weeks and other good offers, so i would suggest checking https://www.mindfactory.de/Highlights/MindStar from time to time. Some offers are just outright horrible but there are some very good ones from time to time.
https://linustechtips.com/topic/1527094-pc-parts-list/#findComment-16099408
If you are willing to order from different vendors (i just choose bigger ones not some small shops) here is a list that i created (and Yes i picked that PSU, but the problem that it once hat should be fixed now according to GN)
PCPartPicker Part List
CPU: AMD Ryzen 7 7800X3D 4.2 GHz 8-Core Processor  (€402.00 @ Mindfactory)
CPU Cooler: ARCTIC Liquid Freezer II 360 56.3 CFM Liquid CPU Cooler  (€105.34 @ Mindfactory)
Motherboard: MSI B650 GAMING PLUS WIFI ATX AM5 Motherboard  (€177.99 @ Mindfactory)
Memory: G.Skill Trident Z5 RGB 32 GB (2 x 16 GB) DDR5-6000 CL36 Memory  (€115.98 @ notebooksbilliger.de)
Storage: Crucial P5 Plus 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (€109.90 @ Amazon Deutschland)
Video Card: ASRock Phantom Gaming OC Radeon RX 7900 XTX 24 GB Video Card  (€984.00 @ Mindfactory)
Case: Corsair 4000D Airflow ATX Mid Tower Case  (€82.90 @ Amazon Deutschland)
Power Supply: Gigabyte UD1000GM 1000 W 80+ Gold Certified Fully Modular ATX Power Supply  (€129.89 @ notebooksbilliger.de)
Total: €2108.00
Generated by PCPartPicker 2023-08-19 00:54 CEST+0200
https://linustechtips.com/topic/1527094-pc-parts-list/#findComment-16099421
Total: €2108.00
+1 for that build with just 2 changes - get that same memory only with CL30, not 36 and get a Corsair RM850x or RM1000x PSU instead of the Gigabyte one. If you get over budget a lot, change the Liquid Freezer II with AK620 or Peerless Assassin 120SE
| Ryzen 7 5800X3D | Arctic Liquid Freezer II 360 Rev 7| AsRock X570 Steel Legend |
| 4x16GB G.Skill Trident Z Neo 4000MHz CL16 | Sapphire Nitro+ RX 6900 XT | Seasonic Focus GX-1000|
| 512GB A-Data XPG Spectrix S40G RGB | 2TB A-Data SX8200 Pro| Phanteks Eclipse G500A |
https://linustechtips.com/topic/1527094-pc-parts-list/#findComment-16100073
