Hi,
i just got my new GPU. It's 7900XTX but i have a small problem. It's 3x8pin GPU, Red Devil. I hav CableMod cables, but ony 2x8pin, so i'm short for one 8pin in my pack. My PSU is Evga 750W G3. So, can i use 2x8 pin by CableMod and one original EVGA 8pin cable that i got with my PSU? Or, should i use only my original Evga cables for GPU. In that case, i can use one original Evga cable that splits into 2x8pin and one original Evga 8pin cable. What is better and safer option?
Is it safe to use just 2x8 pin on 3x8 pin GPU? Guess not?
One more, can i use 2x8pin CableMod and  1x6pin from SATA also CableMod to 3x8pin GPU? That's also a huge no no i guess?
Thanks,
Alen
https://linustechtips.com/topic/1527074-mixing-cables/
You never want to mix cables across power supplies. I am not sure exactly how cable mod works though, are they set up with the same pinouts as your power supply? As in designed to specifically work with your power supply? If that is the case, mixing those cables is perfectly safe. But NEVER use a cable not specifically designed to work with your exact power supply.
My PC Specs: (expand to view)
Main Gaming Machine
CPU:  Intel Core i7-14700K
CPU Cooler: Deepcool LT720
Motherboard: MSI PRO Z790-P WIFI
Memory: G.Skill Trident Z5 RGB 32 GB (2 x 16 GB) DDR5-6400
Storage 1: Samsung 990 Pro 2 TB
Storage 2: Crucial P3 Plus 4 TB
Video Card: EVGA XC3 ULTRA GAMING GeForce RTX 3080 10GB
Power Supply: Corsair RM850 850W
Case: Corsair 7000D Airflow
Case Fan 140mm: Noctua A14 PWM 82.5 CFM 140 mm (x7)
Monitor Main: MSI G274QPF-QD 27.0" 2560 x 1440 170 Hz
Monitor Vertical: Asus VA27EHE 27.0" 1920x1080 75 Hz
https://linustechtips.com/topic/1527074-mixing-cables/#findComment-16098648
Just now, Alen100 said:
Yes, its e-series for Evga PSUs.
I used it on 6700xt, no problems, but that card is 2x8pin. My new card is 3x8pin, so im one cable short. So i can use 2x8pin CableMod and one 8pin that came with ny PSU?
Assuming its the proper cable from CableMod, sure. Otherwise, there's no standard for how modular PSU cables are wired on the PSU end. The other end of the cable is standard, where the only exception to this is 12VHPWR, which is a true 1:1 cable per the spec.
Otherwise if you happen to use the wrong cable, first party or not, you run the risk of having a deadly (for the hardware) 12V to ground or such short that might take hardware with it. Where generally people won't recommend mixing any cables, where I'll generally recommend not using 3rd party cables for this reason unless you're 100% sure its the proper cable.
Builder/Enthusiast/Overclocker since 2012 with a focus on SFF/ITX since 2014.
https://linustechtips.com/topic/1527074-mixing-cables/#findComment-16098702
If it's an original cable that came with the PSU that's perfectly fine. You don't want to mix match other PSUs cables with different PSUs. As long as it's the one that came with the PSU originally it will be fine to use in conjunction with the cable mod cables.
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
https://linustechtips.com/topic/1527074-mixing-cables/#findComment-16098705
With this information (Assuming you have already used these cables with your psu previously, unless I miss understood??) you can mix those cables just fine with no issues.
Main Gaming Machine
https://linustechtips.com/topic/1527074-mixing-cables/#findComment-16098708
The CableMod E-series cables are specifically for EVAG PSUs -- I have a set for each of my EVGA units.
Yes, you can use the 2x CableMod cables, and then one of the original ones that came with the PSU.
Other than...the cables not looking all the same...and if that will annoy you 😆
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/1527074-mixing-cables/#findComment-16098782
