Needing help to identify
Solved by Applefreak,
13 minutes ago, AJChafa said:
That's pre-ITX so you will have to mod it for sure to get a board into that case. It also had really bad airflow at the time and was running really hot on a single core. There was a version with a top 80mm fan under the handle but still quite bad. I believe the PSU was instrumental in cooling the CPU, which won't work on modern PSUs that turn down the fan speed. The model was called Shuttle XPC based on a generic rebranded design. Here is a review of the original case
