I bought Assassin's Creed 1 a couple days ago and have now downloaded it. What is weird that I sometimes get huge lag, which should not be a problem for me because of my powerfull computer, it has normally been lagging for a few seconds and then go back to normal. It was different today, I got all the way down to below 5fps(checked with fraps) and noticed on task manager that my CPU speed was 5GHz while this was happening. I know I have overclocked the CPU to 4.3GHz but not up til 5GHz. I figured since the CPU is working so fast it must be hot, but when I checked with Real Temp the temp was fine. I then noticed something strange, the CPU speed monitored by Real Temp and the Windows Task Manager was different, Task Manager showed 5GHz but Real Temp showed only 4.3GHz. I have no idea of what is happening so I would like to find out.
On the task manager it also says it is running 87 Processes, 1280 Threads, 31300 Handles.
I have an Intel Core i7-3820 @ 4.3GHz on a Gigabyte GA-X79-UD5 motherboard, 16GB RAM and a GTX Titan. I am running Windows 8 Pro 64-bit.
https://linustechtips.com/topic/152694-strange-problems-with-cpu/
Some thing's wrong mate, although i can't be much of help, one thing,Win8 is a bitch, i had similar problems with it, so i removed it, sold my key and went back to Win7
 Crust : Intel Core i5 4690K @ 4.4Ghz 1.45v  |  MotherboardMSI Z97 MPower  |  Fruity FillingMSI GTX 960 Armor 2Way-SLI |  CoolingNoctua NH-D15  |  RAM : 16GB Corsair Vengeance 1600Mhz | Storage : 2xSamsung 840 EVO 500GB SSDs Raid-0  |  Power Supply : Seasonic X-Series 1250W 80+Gold  |  Monitor : Dell U2713HM 27" 60Hz 1440p  |
I have stress tested my CPU for a bit now, the Windows Task Manager still says that it is running at 5.08GHz when the CPU load is 98%-100% but everything else, Real Temp and the stress test utility says that the clock speed is at 4.3GHz at 98%-100% load which it should. It is very weird.
As of writing this message I can read on the task manager that 72 processess are running, 890 threads going and 24600 handles going on.
I'd suggest contacting either Intel (maybe?) or Microsoft directly. Or there's the ever fun walk of shame into best buy with a tower for geek squad to check out.
Dubs are better than subs
