Budget (including currency):
$1500-2000 USD
Country: USA
Games, programs or workloads that it will be used for: FS19, FS22, COD Warzone,
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): Intel, white themed
https://linustechtips.com/topic/1526207-i-need-help/
I did a little building on PCPartPicker and made a build that would meet your requirements (just skating under 2k).
https://pcpartpicker.com/user/5678bam/saved/FsFLyc
Notes: There's definitely an aesthetic tax to be paid going all-white. I was unable to find a really good white motherboard while staying in budget, but if you're willing to splurge on mobo you can check out the NZXT N7 Z790.
The GPU is a highly personal choice; I think a 3080 will work really well for your use-case and I was able to find that one white version on eBay for $800, though your mileage may vary. It's really hard to find a good white GPU at a reasonable price, people mark those up like crazy.
I was looking at using the NZXT H9 Elite for the case (it's really sleek), but ultimately chose the Corsair one for the price.
Let me know if you have any questions 🙂 I love building PCs
https://linustechtips.com/topic/1526207-i-need-help/#findComment-16078242
PCPartPicker Part List
CPU: Intel Core i5-13600KF 3.5 GHz 14-Core Processor  ($285.99 @ Newegg)
CPU Cooler: Deepcool AK620 68.99 CFM CPU Cooler  ($64.99 @ Newegg)
Motherboard: ASRock Z790 PRO RS WIFI ATX LGA1700 Motherboard  ($194.99 @ Newegg)
Memory: G.Skill Ripjaws S5 32 GB (2 x 16 GB) DDR5-6000 CL32 Memory  ($95.99 @ Newegg)
Storage: Western Digital Black SN850X 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($119.99 @ Adorama)
Video Card: PowerColor Hellhound Spectral Radeon RX 7900 XTX 24 GB Video Card  ($999.99 @ Amazon)
Case: Lian Li LANCOOL 216 ATX Mid Tower Case  ($97.99 @ Newegg)
Power Supply: Thermaltake Toughpower GF1 Snow - TT Premium 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($109.99 @ Amazon)
Total: $1969.92
Generated by PCPartPicker 2023-08-14 15:52 EDT-0400
https://linustechtips.com/topic/1526207-i-need-help/#findComment-16078251
https://pcpartpicker.com/list/Xmy234
This is my take on what you could get for a white theme Intel build. Keep in mind I didn't include a gpu as white gpus are hard to find so it made no gpu feel like a good fit tbh. I mean the best I could find was a white 4070 which to me doesn't seem to be what I would want. If I could find a white 4070ti or rx 7900xt I would have opted for that instead
https://linustechtips.com/topic/1526207-i-need-help/#findComment-16078290
Total: $1969.92
i5 is definitely the way to go here.
Ignore my list OP, this one is better (personally I'd still go with the Corsair 4000D case and Vengeance RAM but that's just for the aesthetics).
https://linustechtips.com/topic/1526207-i-need-help/#findComment-16079189
$1500-2000 USD
Country: USA
Need to know your monitor resolution or if a monitor is to be included in the budget.
https://linustechtips.com/topic/1526207-i-need-help/#findComment-16079327
