Hey Guys,
I really need some help on choosing a sound card for my Corsair SP2500 I thought an Asus Essence STX II.
What shall I do?
What motherboard are you running?
You are likely not going to see any improvement over what is built into your board unless you are running say a pentium 4 based system, or your current chip does not function.
Desktop <dead?>
P8P67-WS/Z77 Extreme4/H61DE-S3. 4x4 Samsung 1600MHz/1x8GB Gskill 1866MHzC9. 750W OCZ ZT/750w Corsair CX. GTX480/Sapphire HD7950 1.05GHz (OC). Adata SP600 256GB x2/SSG 830 128GB/1TB Hatachi Deskstar/3TB Seagate. Windows XP/7Pro, Windows 10 on Test drive. FreeBSD and Fedora on liveboot USB3 drives.
Laptop <Works Beyond Spec>
HP-DM3. Pentium U5400. 2x4GB DDR3 1600MHz (Samsung iirc). Intel HD. 512GB SSD. 8TB USB drive (Western Digital). Coil Wine!!!!!! (Is that a spec?).
https://linustechtips.com/topic/152615-sound-card-help/#findComment-2038298
the Asus Essence STX is an ace soundcard, I love mine, plus it has RCA outputs ;)
Corsair 650D, i5-4690K (Corsair h50 cooler), Asus ROG maximus VII Ranger, Asus GTX 980ti Strix, 16GB Corsair Vengeance pro series Red (2x8gb 2400mhz), Corsair HX850W, Asus Xonar Essence STX, Sennheiser HD595 / Beyerdynamic dt 770 pro 250 ohm, Samsung 850 pro 128GB / WD black/blue/green, OCZ vertex 3 60gb . Corsair M40/Corsair k70.
https://linustechtips.com/topic/152615-sound-card-help/#findComment-2038358
I have a sabertooth z87
Test your onboard sound first. There is a very good (as in certain) chance that you will not improve over the onboard with a soundcard except maybe for software.
Desktop <dead?>
https://linustechtips.com/topic/152615-sound-card-help/#findComment-2038398
