I have seen many videos and articles about this, but I want to get down to the bottom of it. By how much does a RAID 0 strip increase speed? Does it combine the speed of each drive? So for example, if I had two 128GB 150 MB/S SSD's, would that give me a 256GB 300 MB/S strip?
Also, I was wondering about RAID 1. Does this RAID decrease speed, or keep it the same? Does this depend on what RPM/Cashe/Data Cable the drives have/are using? Or is the speed alteration [mostly] universal?
Thanks in Advance,
-Shadow
https://linustechtips.com/topic/152585-raid-0-speedraid-1-speed/
-2x128GB, 150MB/s SSDs in Raid1 will give you 256GB with 150MB/s of speed, itch, because raid1 make the two Discs act like two discs, mirror itch other, sort of
-2x128GB, 150MB/s SSDs in Raid0 will give you 256GB with ~300MB/s of speed as total because Raid0 make the two discs act like one
-Raid1 is slower but a bit safer than 0 because ya see, as i said the discs will act like two discs, so there some sort of Lag in the speed the two communicate than if they where in Raid0, but with Raid0, since the two act like one, if one disc fails, boom, all the data stored on both is gone, i hope i didn't mistake any thing
 Crust : Intel Core i5 4690K @ 4.4Ghz 1.45v  |  MotherboardMSI Z97 MPower  |  Fruity FillingMSI GTX 960 Armor 2Way-SLI |  CoolingNoctua NH-D15  |  RAM : 16GB Corsair Vengeance 1600Mhz | Storage : 2xSamsung 840 EVO 500GB SSDs Raid-0  |  Power Supply : Seasonic X-Series 1250W 80+Gold  |  Monitor : Dell U2713HM 27" 60Hz 1440p  |
https://linustechtips.com/topic/152585-raid-0-speedraid-1-speed/#findComment-2038007
Raid 1 would give 128GB space... at 150MB/s... Raid one litteraly does nothing for capacity or speed ONLY ONLY ONLY redundancy...
5820k4Ghz/16GB(4x4)DDR4/MSI X99 SLI+/Corsair H105/R9 Fury X/Corsair RM1000i/128GB SM951/512GB 850Evo/1+2TB Seagate Barracudas
https://linustechtips.com/topic/152585-raid-0-speedraid-1-speed/#findComment-2040812
that's what i said, itch
https://linustechtips.com/topic/152585-raid-0-speedraid-1-speed/#findComment-2040954
