Hey I'm building a custom pc soon and I want a cool affect in my room I want to buy this led (link below) but I want to cut them into strips, so strip under my bed,desk and behide my pc monitor. It's there anything extra I need??
http://www.amazon.com/LEDwholesalers-Controller-2034RGB-3315-3215/dp/B0040FJ27S/ref=sr_1_12?ie=UTF8&qid=1400128151&sr=8-12&keywords=colour+changing+led
https://linustechtips.com/topic/152495-led-strips-help-please/
ive got the same sort of led strip, about every foot there are bare copper parts where you can cut them into shorter sections and  you can solder wires to, to connect multiple strips to, also i have all my strips running off one of my fan takeoffs from my case, no external power sources needed
https://linustechtips.com/topic/152495-led-strips-help-please/#findComment-2037146
I suggest to get one without the external power supply since it`s going inside the case and I'm assuming you'd like the remote controller with the special effects:
http://www.amazon.com/XKTTSUEERCRR-Water-resistant-300LEDs-Flexible-Controller/dp/B00AJJDLHQ/ref=pd_sim_hi_14?ie=UTF8&refRID=1XE54CYK1FYZ7J9H8P6M
https://linustechtips.com/topic/152495-led-strips-help-please/#findComment-2037176
Well no it's going to around my room I was going for around my desktop monitor, celling and bed but I will put it in my case too now
https://linustechtips.com/topic/152495-led-strips-help-please/#findComment-2037779
Thanks
https://linustechtips.com/topic/152495-led-strips-help-please/#findComment-2037781
Wait so do I just cut them into 3 different strips and buy 3 different power supply's and thats it
https://linustechtips.com/topic/152495-led-strips-help-please/#findComment-2037799
Can't you just use the existing power connections from each individual strip and solder new wire onto each end at the separation point of the cut? Or can you only solder wires onto one half? and then solder wires from one gold bit the respective gold bit on the other side? Wouldn't that enable one controller to power and control all the strips?
edit: found a good pic of what i mean
This is what I think of Pre-Ordering video games: https://www.youtube.com/watch?v=wp98SH3vW2Y
https://linustechtips.com/topic/152495-led-strips-help-please/#findComment-2037904
This could be done, if he knows how to solder, and the strips aren't very far apart.
If the desk and bed are on opposite sides of the room, the buying two kits would be much easier, and you could mix and match colors that way. I'm putting separate controllers in the kitchen as my wife wants alternating red and green for christmas, etc.
You'd need a power supply and an IR controller if you want to change colors.
http://www.amazon.com/SUPERNIGHT-TM-100V-Switching-Adapter/dp/B008FKDK2M/ref=sr_1_2?ie=UTF8&qid=1400163445&sr=8-2&keywords=led+power+supply
http://www.amazon.com/SUPERNIGHT-TM-Remote-Controller-Light/dp/B00AF5YOK2/ref=sr_1_2?ie=UTF8&qid=1400163423&sr=8-2&keywords=led+controller
Note that the controller says this on the webpage:
  • Input Voltage: 12V (Power supply is not included. You can easily connect to the standard notebook computer power supply
Don't do that... most laptop power supplies are 19V and you'll likely fry the strips and controller. I had some 3528 LED strips that weren't very bright and I tried running at 19Vs for a bit of a boost, they lasted about an hour.
https://linustechtips.com/topic/152495-led-strips-help-please/#findComment-2038515
