Using two m.2 nvme ssds on motherboard with one slot.
Ntdi
Hello! I've recently upgraded my build with a new m.2 nvme ssd. This new one replaced my old one which had less capacity, but it still good and new. Currently, I'm using MSI's "MPG X570 GAMING PLUS" and that only has one m.2 slot. Is there any adapter/pcie controller that I can use to allow my old drive to be used on my motherboard?
m.2 pcie card
https://www.amazon.ca/s?k=m.2+pcie+card&i=electronics&crid=1KUV4SSIYGJQO&sprefix=m+2+pcie+card%2Celectronics%2C112&ref=nb_sb_noss_1
Quote
CPU-AMD Ryzen 9 5900X / CPU Cooler-Noctua NH-D15S / Motherboard-MSI MPG X570S CARBON MAX WIFI / Memory-G.Skill Trident Z Neo 64 GB (4 x 16 GB) DDR4-3600 CL16 / Storage-WD WDBSLA0040HNC-NRSN 4TB 3.5" 7200 RPM / Storage-WD Red 6 TB 3.5" 5400 RPM--Crucial P3 4TB 3.0X4 NVME--Sabrent Rocket 4.0 1TB 4.0X4 NVME--Corsair MP600 CORE 2TB 4.0X4 NVME / Video Card-XFX Radeon RX 6900 XT / Case-Lian Li O11 Air Mini / PSU-SeaSonic PRIME 1000 W 80+ Gold / Sound Card-Creative Labs Sound Blaster Z w/Shield / Monitor-BenQ GW2765HT 27.0" 2560 x 1440 60 Hz / Monitor-Asus ROG Strix XG27AQ 27.0" 2560 x 1440 170 Hz / Keyboard-Logitech G Pro / Mouse-Logitech G502 LIGHTSPEED Wireless / UPS-CyberPower GX1325U / Fan Controller-Corsair Commander Pro
Quote
CPU-AMD Ryzen 7 5800X / CPU Cooler-Corsair iCUE H100i ELITE CAPELLIX / Motherboard-Asus TUF GAMING X570-PRO (WI-FI) / MemoryG.Skill Trident Z Neo 32 GB (4 x 8 GB) DDR4-3600 CL16 / Storage-Western Digital Black SN750 SE 1TB 4.0X4 NVME--Samsung 970 Evo Plus 2TB 3.0X4 NVME--Seagate Barracuda Compute 3 TB 3.5" 5400 RPM / Video Card-Asus KO Gaming OC GeForce RTX 3070 / Case-Lian Li O11 Air Mini / Case-LIAN LI PCI-E 16 X 4.0 Black Riser / PSU-EVGA SuperNOVA 850 G+ Gold / Monitor-LG 22BK430H-B 21.5" 1920 x 1080 60 Hz / Monitor-MSI Optix 271CQP 27.0" 2560 x 1440 165 Hz Curved / Keyboard-Logitech G413 TKL SE / Mouse-Logitech G502 HERO Wired / UPS-CyberPower CP1350PFCLCD / Fan Controller-Corsair  Commander Pro / Sony HT-S200F Soundbar
Quote
CPU-AMD Ryzen 7 5700X / CPU Cooler-Scythe Mugen 5 Black Edition / Motherboard-MSI MPG B550I GAMING EDGE MAX WIFI / Memory-G.Skill Trident Z Neo 32 GB (2 x 16 GB) DDR4-3600 CL16 / Storage-Samsung 970 Evo Plus 1TB 3.0X4 NVME--PNY CS900 1TB 2.5" SSD--Samsung 970 Evo Plus 2TB NVME/ Video Card-EVGA XC GAMING GeForce RTX 3060 / Case-Cooler NR200P / PSU-Cooler Master V750 SFX GOLD / Keyboard-HyperX Alloy Origins Core / Mouse-Logitech G502 HERO Wired / UPS-CyberPower LE1000DG-FC / Fan Controller-NZXT RGB & Fan Controller
Quote
CPU-AMD Ryzen 7 5700G / CPU Cooler-Scythe Shuriken 2 / Motherboard-Gigabyte X570 I AORUS PRO WIFI / Memory-Corsair Vengeance LPX 32 GB (2 x 16 GB) DDR4-3800 CL18 / Storage-WD Blue 1TB 2.5" SSD--Samsung 970 Evo Plus 1TB 3.0X4 NVME--Patriot P310 1.92TB 3.0X4 NVME / Case-InWin B1 Mesh / Keyboard-Logitech K380 / Mouse-Logitech G502 LIGHTSPEED Wireless / Monitor-ViewSonic VX1755 17" 1080p Portable IPS Gaming Monitor 144Hz / Speakers-Creative Muvo Go (Black)
I bought an external "enclosure" but it lets me hot swap, essentially. It even has a power button, so I eject a drive, turn it off, swap drives, turn it on, and I am good to go. Obviously you need a USB C port, but it looks like your motherboard has one on the back.
https://www.amazon.com/gp/product/B084ZKLQR8
This sounds promising, are there speed losses with this method?
There are always speed losses with USB C, but I mean the speeds are so fast that I just don't think it matters that much. It's consistent and reliable, which is saying a lot for a USB C device. It will fully saturate a 10 Gbps connection during transfers. But if you need full NVME bandwidth, get an internal card as @wONKEyeYEs linked. You need PCIE lanes for full bandwidth with NVME.
Just depends if you need a built in unit that you are rarely going to replace or if you need to hot swap/access infrequently. I use my enclosure for data back up and backing up my RAW images after I edit a photo shoot. It's also especially useful when I am going to format a computer. It's very handy for that.
I would not use this external enclosure for 24/7 daily use. Get an internal expansion card for that.
Alright, i’ll look into pcie expansion slots as this would be for 24/7 use
14 minutes ago, Zagna said:
I count 2 NVMe slots?
Hmm.. I don’t see the top most slot on my board, i’ll double check.
It's behind the M.2 heatsink that you can see in the bottom left corner of the image.
i see 2 slots, look better
why would you buy this instead of NVMe expansion card slot?
Because it’s external and I can swap the drives or connect to multiple computers very quickly. I don’t have to unplug everything and remove the side panel and unscrew the board every time. Plus I have a mini itx case for my main. I could not use an expansion card if I wanted to.
  • 2 weeks later...
It has two slots! The second slot was covered by my gpu, Thanks to everyone for their advice.
If you have one NMVe slot on your motherboard you can buy a separate NMVe PCIe board which can hold 1 NMVe slot with a 4x PCIe slot. 2 NMVe's or 4. Needs a 16x slot. (Nice if you need more NMVe's in the future.)  But be aware. Speed is everything. NMVe's comes (today) into 2 tastes; PCI 3.0 or 4.0 speeds. If you want 4.0 speeds each step must be compatible with the standard. 1st; The motherboard . (Chipset) 2nd; The NMVe card itself. (some are 3.0, the newer ones 4.0) And 3rd; The controller of the separate NMVe PCIe card itself. If one works at 3.0 then you will end up with that speed. If your PCIe x16 card can house 4 NMVe's there is a 4th issue; The BIOS must be able to set the setting "bitfurication" setting to ON.
There are some 4 x M.2 PCIe 4.0/3.0 X16-adapter you can buy. Promise everything but look first at their review's first. You need to have a modern chipset that also support 4.0 speeds; Chipsets support PCIe Bifurcatie: Intel Platform X299, C422, C621, Z390, Z370, Z490, Z590, Z690, X99; AMD Platform: TRX40, X399, X570, X470, B550, B450, Z59, Z59, 0, enz.
One thing is not very clear; one says to set your PCIe settings to 4x4x4x4x. I have a PCIe 5.0 graphics card. That means in theory that I am throttling down my 5.0 GPU to 4.0 speeds. 5.0 is the new standard that is emerging just like DDR5 and 6. I bought a ASUS Prime Z690 motherboard which can house 4 NMVe's at PCI 4.0 speeds. (This will be the new standard from now on. No more SATA HDD's and SSD's anymore) I know that I have 2 NMVe's that are 3.0 and 2 that are 4.0. (The NMVe's are on the rise again just as we saw with SATA HDD's and SSD's. More speed and capacity) Can't tell if my 4.0 NMVe's are working at 4.0 speeds. Takes time to settle the dust I guess...
Tests are also a subject of debate. Tests showed that my new 5.0 GPU card would work in a 3.0 motherboard. (backwards compatible) It didn't (for me). Windows 11 and strange blue screens. Motherboard was 7 years old. To old it seems..... Bought a new 12th gen i7 CPU (i9 is to expensive. Budget. You must have one!), Z690  (Z790? Budget) motherboard and 32Gb DDR5 to renew my machine. That new RTX3060TI (Budget) resulted into more costs than I expected. But it is very speedy indeed for not a top dollar price. Can use it for the next 10 years. One plus; absolute no sound. Was also the case with my old motherboard with a 4th gen i7 CPU, 32Gb DDR4 and a GTX1080. Motherboard had 2 NMVe 3.0 slots back then. Added 1 more by using a 3.0 separate PCIe card. unfortunately we see also an other trend; Lesser PCIe slots. 2 16x slots and 1 1x and 4x slots. 1x and 4x slots will disappear also in the end. Firewire and USB3.2 are here.... Even 4.0 NMVe's external cabinets..... With the speeds comes also the heat. DDR5,6 and NMVe 4.0 need coolers to cool things down. Get used to it. On my motherboard sits 3 heat spreaders for the 3 NMVe 4.0 devices. On the 4th one? None. Had to use a separate cooler to reduce it's 4.0 heat. These device with a cooler will be more common than now. They already have a cooler fitted on the device. Separate? Don't pull off the sticker. It's aluminum based and will void your warranty if you pull it off. Heat will reach the cooler anyways. Sticker is not an insulator. Thought about it. Future external coolers. If it it fitted by the manufacture then the cooler is placed directly onto the chips and the sticker on the outside. No need there to pull it off. There is a lot to know about NMVe's. To get the most out of them; you need knowledge about the subject. Not what the manufacture promise. They will do anything to sell there products. Those 4 rules are a real nutbuster even for the informed ones. Will go away in time for sure! But transitions are hard to understand.
"We have a 8K television you can buy..." More resolution, better etc. As long as the cable sends you HD or 4K quality... It's useless. Al they can do to look likes it's a higher definition As long as the source isn't it is just make-believe. Rules also apply to computers. You want one thing (speed) but..... There are conditions attached to it.
Just babbling as a Nerd on a nerdplatform......
