AMD downsampling Help
Go to solution Solved by MrYuriy,
I use display fusion on both
That MIGHT, a very strong might, be the reason. Maybe a glitch in Dual Display Fusion + Dual Downsampling bug?
Either way.. I doubt that's your problem. I really don't think that the XFX 6950 can push two 1440p monitors, especially two that were downsampled + non-native.
Luck of the draw, be happy.
Le Bastardo+
i7 4770k + OCUK Fathom HW labs Black Ice 240 rad + Mayhem's Gigachew orange + 16GB Avexir Core Orange 2133 + Gigachew GA-Z87X-OC + 2x Gigachew WF 780Ti SLi + SoundBlaster Z + 1TB Crucial M550 + 2TB Seagate Barracude 7200rpm + LG BDR/DVDR + Superflower Leadex 1KW Platinum + NZXT Switch 810 Gun Metal + Dell U2713H + Logitech G602 + Ducky DK-9008 Shine 3 MX Brown
Red Alert
FX 8320 AMD = Noctua NHU12P = 8GB Avexir Blitz 2000 = ASUS M5A99X EVO R2.0 = Sapphire Radeon R9 290 TRI-X = 1TB Hitachi Deskstar & 500GB Hitachi Deskstar = Samsung DVDR/CDR = SuperFlower Golden Green HX 550W 80 Plus Gold = Xigmatek Utguard = AOC 22" LED 1920x1080 = Logitech G110 = SteelSeries Sensei RAW
https://linustechtips.com/topic/152423-amd-downsampling-help/#findComment-2035977
I am running my monitor at 2560 X 1440 but i have 2 monitors and i can only seem to get one display to run at 2560 X 1440
Is there something specific happening on the 2nd monitor that isn't allowing you to do so?
• Is there an error, or what?
• Are they the same two monitors?
• What components (particularly GPU) are you running?
Etc...
Details please.
« Current PC ~ Phantom Beast »
https://linustechtips.com/topic/152423-amd-downsampling-help/#findComment-2035988
Etc...
Details please.
One monitor is a 24 and the second is a 23 both Acer, my card is a XFX 6950 and i use Display fusion
https://linustechtips.com/topic/152423-amd-downsampling-help/#findComment-2036019
Are you using Display Fusion on the one that won't Downsample?
Also, I highly doubt that GPU can power x2 1440p monitors...?
https://linustechtips.com/topic/152423-amd-downsampling-help/#findComment-2036053
https://linustechtips.com/topic/152423-amd-downsampling-help/#findComment-2036280
That what i was starting to think.
So i am stuck with a 1440 and a 1080 res for now then
https://linustechtips.com/topic/152423-amd-downsampling-help/#findComment-2036339
Better than x2 1080p Monitors, eh?!
Always think positively!
https://linustechtips.com/topic/152423-amd-downsampling-help/#findComment-2036350
