1 minute ago, PC Player said:
I just finished building my first PC yesterday, and when I was downloading Valorant, I got two Riot Client shortcuts, a pic of them are attached below. Does anybody know whats happening?IMG_1551.thumb.jpeg.6e12677f66a098d1c587ab91d6e8411d.jpeg
Yep, one is the program and one is the shortcut for the program 😄 Delete the one at the bottom, that is the shortcut.
Basically you duplicated the icon.
https://linustechtips.com/topic/1524033-two-riot-clients/#findComment-16064253
How did I do that? And how do I delete the shortcut without deleting the program?
https://linustechtips.com/topic/1524033-two-riot-clients/#findComment-16064258
Who knows, shit happens.
Its a shortcut.  It won't delete the program, the shortcut is basically just the icon on the desktop.  NOTHING will be delete EXCEPT the shortcut icon on the dekstop.
https://linustechtips.com/topic/1524033-two-riot-clients/#findComment-16064259
Just now, PC Player said:
Alright, thanks!
No Problem 🙂  Even if you delete the original Riot game icon on the dekstop, the program will not be deleted from the computer, JUST that icon will be gone.  Go down to the left and type in Riot and it should pop up for you to click in case that happens. 🙂
https://linustechtips.com/topic/1524033-two-riot-clients/#findComment-16064263
I also used to have a shortcut/program called Valorant with the riot client logo, in addition to what I assume was the regular Valorant. Any idea what that was?
https://linustechtips.com/topic/1524033-two-riot-clients/#findComment-16064276
