Can someone please help
Go to solution Solved by Spotty,
Looks like memory artifacting. You could try a different display cable but I doubt it will help. Submit a warranty claim for a replacement.
As a band-aid solution you can try downclocking the memory speed by 100MHz or so and see if that helps. Given that it's not happening in all games it's possible that a lower memory clock speed will help fix it, at least until you can get it replaced.
Just now, Davidsaywut said:
Is this artifacting or what? 6900xt purchased 10/21  I have videos also but they’re too big to upload
Try updating your gpu drivers after a ddu of your old ones. It may also be the cable so if you have another one try that. Or a different displayport port on your gpu
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
Does indeed appear to be artifiacting. You can upload videos to Youtube and post the video if that helps.
Contact the graphics card manufacturer to get a warranty claim going and replacement card.
Hows this my friend, also thank you all for the replies
Does it only happen in Tarkov or in all games?
i have done the drivers, even fresh installed, tried on two different PC also, 13600k and a 7800x3D
only thing in common on both is GPU and cables, i could try cables
thank you for your time and help
