Nvidia Surround, profiles (swapping between setups)
Hello
I just bought 3x VN247H from asus to use in a multi monitor setup, now iv serched the net for a fix for the folowing problem, but i havent found any usefull information, and most of it is outdated.
I use Windows 8.1, with a 780Ti
Problem:
I can create a costum resolution that works well for some games, and the desktop i really like. But there are certan game which i need the extented desktop and not a sourround setup. I need in some cases the pc to detect all 3 monitors separately.
Is there a fix, shortcut to change thies settings? perhaps a program to manage this?
Help will be much apriciated
/Chris
