Trying to build my first custom pc. I don't know much and I need some help (please)
9 hours ago, monkegoboomboom said:are you saying that my Ryzen 5 7600 is not good enough for 1080p?
Frame time wise they're inferior to full 8 core especially if you have side applications open. At 1080p, your CPU should be more than needed because that's what really control games consistencies in that resolution thanks to the lessened GPU load.
3 hours ago, monkegoboomboom said:CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor ($226.99 @ Amazon)
CPU Cooler: Deepcool AG620 BK ARGB 67.88 CFM CPU Cooler ($47.99 @ Newegg)
Motherboard: MSI PRO B650-P WIFI ATX AM5 Motherboard ($189.99 @ Amazon)
Memory: G.Skill Flare X5 32 GB (2 x 16 GB) DDR5-6000 CL36 Memory ($92.99 @ Amazon)
Storage: Western Digital Black SN770 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive ($94.18 @ Amazon)
Video Card: MSI VENTUS 3X OC GeForce RTX 4060 Ti 8 GB Video Card ($399.00 @ Newegg)
Case: Montech AIR 903 MAX ATX Mid Tower Case ($74.99 @ Newegg)
Power Supply: Corsair RM750e (2023) 750 W 80+ Gold Certified Fully Modular ATX Power Supply ($99.99 @ Best Buy)
Operating System: Microsoft Windows 11 Home OEM - DVD 64-bit ($117.98 @ Other World Computing)
Case Fan: Corsair iCUE SP120 RGB ELITE 47.7 CFM 120 mm Fan ($17.00 @ Amazon)
Total: $1378.10
Generated by PCPartPicker 2023-08-01 17:56 EDT-0400
This is still a pretty woeful build. Thanks for saying that your budget is more like 1300 bucks though, this is something id build instead.
CPU: AMD Ryzen 7 7700 3.6 GHz 8-Core Processor ($313.99 @ Newegg)
CPU Cooler: Thermalright Peerless Assassin 120 SE ARGB 66.17 CFM CPU Cooler ($37.90 @ Amazon)
Motherboard: Gigabyte B650 GAMING X AX ATX AM5 Motherboard ($179.99 @ Newegg)
Memory: G.Skill Flare X5 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory ($102.99 @ Amazon)
Video Card: XFX Speedster SWFT 309 Radeon RX 6700 XT 12 GB Video Card ($329.99 @ Newegg)
Case: Deepcool CG560 ATX Mid Tower Case ($69.99 @ Newegg)
Power Supply: Deepcool PM850D 850 W 80+ Gold Certified ATX Power Supply ($92.99 @ Newegg)
Total: $1222.02
Generated by PCPartPicker 2023-08-01 21:19 EDT-0400
Although, you are in a bit of a crossroad price because for 1400 USD you could get 6800XT or RTX 4070 which would be the first 4000 series nvidia id actually recommend to buy, and kinda max out what 1080p can use in terms of GPU except in cases where the GPU scales to infinity like in Unreal Engine 5 based titles like Fortnite.
