Need help with gpu cables
Solved by SorryBella,
9 minutes ago, 16marcello said:GPU: Sapphire Nitro+ 7900 xt
PSU: Corsair RM850x
More than fine. Seen more wins with RM850x pigtail than otherwise, not all pigtail connectors are made equal. And for stock operation, the 7900XT shouldn't really exceed the 300-350W limit of these cable even in worst case scenario. Save that for when you want to buy a custom cable kit.
