Help with building my PC
st1r
Budget (including currency): 1.000€
Country: Germany
Games, programs or workloads that it will be used for: Cities Skylines, CS:GO, League and Valo
Parts in my PC that stay:
GPU: RX 7600
Case: Fractal Design Meshify C
CPU-cooler: BeQuiet Dark Rock 4
SSD: Samsung 1TB 980PRO
Parts in my PC that i want/are optional to upgrade:
CPU (definetly): AMD Ryzen 5 3600x
Mainboard (optional): b550 a gaming rog asus
RAM (optional): 32Gb of RAM. Dont know what exactly.
Power adapter (definetly): some 750W thing. Idk for sure.
I would like to buy the parts over a span of 2 - 3 Months. Im just going to put money monthly aside for the parts.
I have two Monitors. My Main Monitor has 144HZ, AOC G2490VXA LED with 1920 x1080P, and i would like to have 144FPs constantly in my multiplayer games and as much as possibly FPS for cities skylines and the upcoming cities skylines 2. I also would like to be as quiet as possible. I would be ready to spend some extra for it.
If u have further questions just ask. Idk if i can answer them properly but i will try my best!
Thanks for reading it all and thanks for the help :). Have a good day!
Country: Germany
GPU: RX 7600
do you want to go to AM5 or stay on AM4?
Continue saving until you reach your budget then post again. Prices are constantly changing and new products constantly appear.
Did you consider just upgrading to a 5000 CPU?
i think i want am5. Cause if im going to upgrade my gpu in the future i dont want to also upgrade my cpu again. Sorry for the late response
u mean something along  an AMD RYZEN 5 5600 or so? Sorry for the late response
Given the budget you could go for a higher performance CPU. If you are mostly gaming you could consider the 5800X3D. You may also want to consider a new PSU, depends on exactly what you currently have.
Country: Germany
GPU: RX 7600
https://geizhals.de/   <--- check this site for better prices
Update your boards bios first.
PCPartPicker Part List
CPU: *AMD Ryzen 7 5700X 3.4 GHz 8-Core Processor  (€184.90 @ Amazon Deutschland)
Video Card: *Palit Dual GeForce RTX 4070 12 GB Video Card  (€607.99 @ Mindfactory)
Total: €792.89
Generated by PCPartPicker 2023-07-28 18:06 CEST+0200
Total: €792.89
Why u want me to upgrade my new GPU? Isnt the RX 7600 fine?
okay, thank you! And yea the PSu i want to update
I missed that part. If so then the 5800X3D would be the obvious upgrade.
Okay. Thank you 🙂
the B550-A Gaming board is yours? Yeah, maxxing it out with 5800X3D would make the most sense here with the massive cache and IPC increase. What's the PSU model number, if you can discern that? Or at least some pictures. We can slip in a reliability upgrade if its a no brand. RAM Speed, or at least the sticker photo in the back? Also what's your cooler?
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
I am human. I'm scared of the dark, and I get toothaches. My name is Frill. Don't pretend not to see me. I was born from the two of you.
Sorry for the late rersponse. I got over the weekend corona and im recovering from it. The RAM has 3.200 MHz and for the PSU i cant get the number currently since im tied to my bed. Sorry and thanks for ur help 🙂
