I need a good monitor arm for two monitors, i need recommendations
Aletzxc
I need a good monitor arm for two monitors, can you guys recommend me some monitor arms?
What kind of arms are you looking for and what kind of displays are you looking to put on them? the strength and reach requirements for dual 22in Flat screens is a lot different then dual 32in curved. Straight, fixed arms are also a lot cheaper then fully articulating hydraulic arms. Don't just get ones that are overbuilt though because then they may not let a lighter weight display sit properly without shooting up to maximum height.
