Choice between tweo first pcs
Solved by Joker-_-Glitch,
3 minutes ago, steve56kd said:You get the idea that this is my first pc right and i dont really need an overkill system right now. Later on probably will upgrade but right now i do not need the power of higher components. Will only use it for studying and light gaming and thats it. People like u are just sad. Damn
take whichever one is cheaper, you won't regret it with any of those cpu
