7900XT Reference card should i bother with a repaste or leave as is?
Solved by YoungBlade,
The max junction temp for the RX 7000 series cards is 110C, so you're still 17C away from that. As long as the card isn't thermal throttling, which it shouldn't be if that is actually the maximum temperature it reaches, then I don't think a repaste is necessary.
If it makes you personally feel better about things, that's fine, but do remember that there are some minor risks associated with a repaste, the most likely being tearing a thermal pad, which could harm VRM or memory temps as a result, or doing a poor mount on the GPU die, which could result in worse temperatures than what you have now, and needing to do it all over again. Basically, I'm arguing for "if it ain't broke, don't fix it."
