I've had two logi m650 mice for about eight months, and so far they've been pretty reliable. However, recently they've been getting laggy when gaming and the connectivity has been dropping sporadically. I've ended up using the mouse that came with my prebuilt from CyberPowerPC. While I like the RGB on the free mouse, it's a bit big for my hands and the buttons have a horrible ping sound. I'd rather not continue to use the CyberPowerPC, so I'm hoping to fix the connectivity issues on the logitech mice.
Does anyone have some tech tips for fixing the logi m650's connectivity issue? Alternatively, got any suggestions for a similar size/weight mouse?
https://linustechtips.com/topic/1521815-connectivity-issues-on-logi-m650/
Plug the dongle on separate USB port, I mean there's no other usb devices plugged around it.
I've had this issue with Logitech M510, I read online somewhere, the connection issue came due to the USB dongle plugged into a USB 3 port and near other usb devices. Anyway, by separating the dongle, I fixed the issue.
For example, if your case has a front USB port, don't plug anything else there, just the mouse dongle.
Occassionaly visits the forum when I have nothing to do at work.
Thanks! It's worth a shot, I'll let you know if it works.
