Hello, I've been working on setting up an Azure DevOps pipeline this week, aiming to build C++ and C# Projects from the repository. Unfortunately, I haven't been able to accomplish this successfully yet, as my knowledge of pipelines is somewhat limited.
The crucial aspect is ensuring that the pipeline builds the projects in the same order as the Visual Studio Build Settings dictate. For clarity, here's an example of the desired build order:
  1. C++ Project
  2. C++ Project
  3. C# Project
  4. C++ Project ...
It's important to follow this order as the projects have dependencies on each other as the list progresses.
I'm hoping to find assistance from someone experienced in Azure DevOps pipelines to help me achieve this objective and attain a successful build on Pipelines.
Current YAML:
trigger:
- azure-pipelines-second
pool:
  vmImage: 'windows-latest'
variables:
  solution: '**/*.sln'
  buildPlatform: 'Any CPU'
  buildConfiguration: 'Release'
steps:
#Installments
- script: choco install netfx-4.8 # .NET Framework
- script: choco install windows-sdk-10-version-1903-all # Windows SDK
- task: NuGetToolInstaller@1
- task: NuGetCommand@2
  inputs:
    command: 'restore'
    restoreSolution: '**/*.sln'
    feedsToUse: 'config'
    nugetConfigPath: 'NuGet.config'
- task: MSBuild@1
  displayName: 'Build Proj01'
  inputs:
    solution: '$(solution)'
    platform: 'x86'
    # configuration: '$(buildConfiguration)'
    configuration: 'Release'
    msbuildArguments: '/t:Proj01 /restore'
Main Error from this:
##[error]MainSolution\MainProject.vcxproj(0,0): Error MSB4057: The target "Proj01" does not exist in the project.
https://linustechtips.com/topic/1520845-urgent-devops-pipelines-c-c-solution/
this one is pretty self explanatory, that target project is not found.  You can try to build your own app using msbuild on your own computer and pass the arguments you used there to your yaml file.
  • 2 weeks later...
Sorry on the delay. I get that but I have tried copying the built files to a directory then adding
AdditionalLibraryDirectories to the folder the built items are copied too but still cant locate the file even thought the console states it was copied.
