Help me
Go to solution Solved by filpo,
Just now, Ruivo2000 said:
Rm850 ?
or the rm850x
Just now, AngerIssuFlo said:
Questions: How much ram do you have? How many storage? How many case fans? RGB or not?
This won't make much of a difference to total power draw. Even if they had 10 case fans all with rgb and 2tb of nvme storage with 64 gigs of ram that should be around 50w
2 minutes ago, Ruivo2000 said:
I have  i7 13700k and red devil 7900xtx what power supply should i buy?
At the least a 750w psu but I would go for an rm850x or a thermaltake 1000w GF a3
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
https://linustechtips.com/topic/1520688-help-me/#findComment-16041809
5 minutes ago, filpo said:
850 recommendation for context but 650-750 can POST. Just not ideal.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
https://linustechtips.com/topic/1520688-help-me/#findComment-16041815
My way is going to a 850w power supply the problem is that I don’t know what r the best models
https://linustechtips.com/topic/1520688-help-me/#findComment-16041823
Cpu is like 250w and gpu is likely 400w at worst
you can problably get that thing to run on a 650w with a decent bit of undervolting but id just follow the gpus reccomended psu wattage of 850w or if significantly cheaper 750w
As for psu pricing
750w ~80-90$
850w 100-120$
Avoid paying any higher as you are essentially getting ripped off with no noticable benifit
https://linustechtips.com/topic/1520688-help-me/#findComment-16041824
I would probs go for an rm1000x or this thermaltake psu Thermaltake Toughpower GF A3 - TT Premium Edition 1050 W 80+ Gold Certified Fully Modular ATX Power Supply (PS-TPD-1050FNFAGU-L) - PCPartPicker
Total: £1040.95
https://linustechtips.com/topic/1520688-help-me/#findComment-16041826
Whatever has the best quality of RMA with solid internals for reasonable price. Good rule of thumb and place to check that is CultistNetwork PSU Tier List, @Somerandomtechyboi price range is also a good one but heavily depends on your economy.
https://cultists.network/140/psu-tier-list/
If you need their sources, the spreadsheet is linked in their page. Its in this tab.
https://linustechtips.com/topic/1520688-help-me/#findComment-16041830
3 minutes ago, Ruivo2000 said:
DeepCool PQ850M 850W 80+ Gold Modular
Its good?
It's alright but a corsair unit is better
Total: £1040.95
https://linustechtips.com/topic/1520688-help-me/#findComment-16041864
Rm850 ?
or the rm850x
Total: £1040.95
https://linustechtips.com/topic/1520688-help-me/#findComment-16041872
Total: £1040.95
https://linustechtips.com/topic/1520688-help-me/#findComment-16041888
3 minutes ago, filpo said:
What is the difference between rm850 rm850x and rm850e
https://linustechtips.com/topic/1520688-help-me/#findComment-16041892
Just the quality of the capacitors, not too major so I wouldn't stress it
Total: £1040.95
https://linustechtips.com/topic/1520688-help-me/#findComment-16041894
34 minutes ago, Somerandomtechyboi said:
You mean basically irrelevant?
You really wont see any diff between these irl, so stay under 120€ for an 850w, gq is a pretty solid unit
Ye that’s what I meant
Total: £1040.95
https://linustechtips.com/topic/1520688-help-me/#findComment-16041953
