RTX 4090 keeps running on x16 Gen 1
Solved by hbdw,
Hey,
Just giving an update on the issue. I think there is some compatibility issues with my AM4 motherboard paired with 4090. I have changed the motherboard to an AM5 (also resulted in a change of CPU) and everything works fine.
What lead me to believe its a compatibility issues is that my old AM4 motherboard still works with other GPU such as 3070 TI. So, hardware-wise it shouldn't be damaged due to the fact that its still functional under a different hardware. There is no hardware deformation (like CPU bended pins, etc).
So, yeah for anyone that is looking to find a way to solve the problem. You could add this one possibility into the list. Hope it helps!
